Question about Baxter Ovens
Where is the pilot light on the baxter rotating rack oven??
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 26 Answers
No pilot. Glow coil ignition.
Posted on Dec 04, 2016
4 Suggested Answers
  • 910 Answers
SOURCE: Hi! I have a baxter OV300 1999- The rack stops
I suspect the drive bel tis worn and slipping.
Please refer to Page 28 of the manual at the link below to inspect the belt.
If this is OK and/or you need any further assistance then please just ask.
Posted on Jul 21, 2011
SOURCE: My baxter rotating tray oven is not baking cookies
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Posted on Dec 30, 2011
SOURCE: i have a baxter mini
Sounds like you have a water leak! The right side panel needs to come off. Here you will see your copper water lines. Try steaming while watching to see where the water is coming from, most likely its coming from the two spray nozzles that enter the oven near the top in the front and rear. If the leak isn't obvious have an authorized technician service the oven. A leak in this part of the oven left unattended could cause more damage and potentially a fire.
Posted on Jan 13, 2012
Pilot light either won't light or won't stay on
Check for a draft first that is randomly blowing this thing out and second check the gas regulator.
Mar 12, 2014 | Baxter Ovens
The top bar on the inside that holds the racks has stopped spinning during bake.
The top bar, referred to as the "carrier" will only rotate when you start your bake cycle. If there is an issue with the rotation you should hear a steady buzzer about once every second. If you are hearing the buzzer that means the rack alignment switch isn't closing momentarily during rotation like it should be. This could be a result of a number of things, such as a bad rack switch, mis-adjusted rack switch, burned or broken wire on rack switch, bad rotation motor, rotation motor chain or sprockets fell off or are loose, or the shaft switch bar is loose (unlikely).
If you are NOT hearing the beeping then the carrier inside the oven itself could have some loose set screws and the shaft could be spinning freely inside the carrier.
Look on top of the oven and you will see a rectangular shield covering the lift and rotation assembly, remove these covers and verify if the shaft is spinning and hitting the little switch mounted near the top of the shaft.
Mar 01, 2011 | Baxter BXA2G Stainless Steel Gas Single...
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
Rack does not stop at the right positin
This could potentially be a very easy solution. First you need to verify if when you open the door does the carrier stop immediately regardless of where it is in its rotation or does it continue to a certain point every time and stop in the same place?
If it stops in the same place you need to adjust the alignment bar on top of the shaft. On top of the oven remove the metal shields covering the rotation and lift assembly. You will see a steel ring with two small bars coming out of it attached to the top of the shaft, these bars strike the rack alignment switch when the come around. Have someone on the ground center the rack carrier. Loose the metal ring set screw and turn it until it is sticking the switch, you'll hear it click. Tighten it a little bit and have them start the oven and open the door to see if it stops straight. Continue making adjustments until it is stopping straight.
If when you open the door the rotation stops immediately regardless of which way the carrier is pointing then you have an issue with your rack alignment or pointer switch. Usually in this case the switch needs to be replaced, but sometimes its just a matter of a wire fell off the switch. Before you try to replace any wires make sure the power to the oven is off.
Jun 05, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Oven with an attitude
Check the lineator actuator motor. If you remove the top cover there should be a strip of metal stuck on the cover to put pressure on the gear to keep it from free wheeling down. These is a tiny button/nipple that sits in the hole in the top of the gear shaft. Lose it and you're sunk. Work with good light and watch the grease. Good luck
Feb 27, 2009 | Baxter Ovens
Ovens Logo
112 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
ray gallant
Are you a Baxter Oven Expert? Answer questions, earn points and help others
