Question about Samsung Washing Machines
I have a Samsung washer wf410anwxaa the display shows LE and won't. Start. Change the motor assembly and magnetic and still doing the same.
    Habit-Forming:
  • 155 Answers
The manual says LE code means your washer has tried to fill but has not reached the proper water level.
Posted on Apr 17, 2015
KevinWhite
  • 1902 Answers
SOURCE: My 7 year old LG
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Posted on Aug 29, 2011
SOURCE: Error code LE
Just unplugging the washer and resetting it solved the problem
Posted on Aug 03, 2007
SOURCE: LG WM 1832CW
if your getting LE code on your LG washer check if your hot and cold water is hooked up right
Posted on Jan 28, 2008
  • 158 Answers
SOURCE: when trying to start washer LOC shows on the
Unplug the washer power cord and plug it back after 2 minutes and see if the washer reset it self. I think it will.
Posted on Oct 01, 2009
  • 1937 Answers
SOURCE: Kenmore washer model 11026912691 magnetic latch assembly
I have to assume that you mean the "Lid Switch"
See the following Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26912691
Look at the sub-component section on the top and cabinet and you should be able to see how the switch connects.
If you cannot tell from the schematic, I' d use the Whirlpool number for the switch (peobably 8054980) and go to dome of the on-line washer parts dealers for a better look. The Whirlpool parts site doesn't have pictures of their parts.
Posted on Oct 11, 2009
A Samsung washer wf410anwxaa. Display a code LE and SR, what does it mean?
Dear jose plz following the link it will help you about your query
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?modelname=WF409ANW&from_osc=&idx=419369&modelcode=WF409ANW/XAA&
https://youtu.be/HXHRPd8VisE
Apr 17, 2015 | Samsung Washing Machines
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
The washer is stopping midway through the load and an error codeLE what seems to be the problem
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
Dec 20, 2010 | Samsung WF337AA Front Load Washer
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
Washing mashin is writing error LE what does it mean?
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 06, 2010 | Samsung WF337AA Front Load Washer
HOW CAN I FIX LE ERROR WM1832CW? HOW CAN LE ERROR ON LG WASHER MODEL WM1832CW? I HAVE UNPLUGGED, I HAVE RESET BY HOLDING START PAUSE BUTTON FOR AT LEAST 10 SECONDS, BOTH AS SUGGESTED BY LG AGENTS. THE...
I had the same problem as you. You will have to order Part# 6501KW2002A from the Repair Clinic. It's called a Sensor Assembly-Hall (Motor) Sensor. For some strange reason this little part goes bad and keeps your washer from turning. To replace this part, all you do is take off the back panel; it has 4 screws. Once you get the panel off you should see a round cylinder with one big bolt in the back of it. Take the cylinder off and you should see a magnetic circle with at least 6 bolts to it. Take each bolt off and slide off the magnetic stator assy. Be careful because when you take off the connectors you don't want to break in wires to the stator assy. You will see the Hall Sensor. It's a small platic piece that attaches to the Stator Assy. Take it off and replace it with new one. Your done.....
Jul 01, 2009 | LG WM-1832C Front Load Washer
Samsung washing machine shows error "LE"
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
LE display
Hi again,
Any developments with the LG washer?
Jul 13, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
