Verizon signal booster plugged into my router, router got wet/shut off. I want to bypass it but the signal booster doesn't seem to be operating right. Is it possible fried through the ethernet cable?
  • 29 Answers
The signal booster cannot operate without a good, working internet connection. Until the router is replaced, the booster will not work.
Posted on May 27, 2015
Dionnow
  • 61 Answers
SOURCE: DGL-4300 resets every few seconds
Try the following:
1. Hook up your router like you want it to be
2. After the WAN/Wireless lights turn off we want to HARDRESET your router.
3. There will be a small hole that requires a pen or paper clip to press...Hold this down for about 15 seconds, or untill the power light flashes on your router.
This might take care of it.
let me know.
Posted on Jan 10, 2008
  • 221 Answers
SOURCE: Unplugged per cable company instructions & not won't connect
The configuration of your cables is correct, as long as your modem is connected to the 'internet' port on your router. You must unplug the power cord from the back of your modem and plug it back in so that the modem recognizes the router. After doing this you should be able to get to the internet.
The modem has a security feature that only recognizes one physical address. When you were plugged directly into your pc, it had the pc's physical address saved in its memory. When you reconnected to the router, the modem blocked the router's access to the internet because the physical address of the router did not match the physical address that was saved in memory.
Posted on Apr 13, 2008
SOURCE: Connecting DLink thru Comcast Cable Modem and Vonage box
i have comcast wifi and i cannot set up vp eye to eye. i try to make phone call and get message says the phone number i call is unregistered. pls help me! thanks. my email is deafjrt@aol.com
Posted on Sep 17, 2008
  • 905 Answers
SOURCE: No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Posted on Oct 14, 2008
Happy2Help
  • 59 Answers
SOURCE: Installing a linksys router with a u-verse RG.
Hi sgolob48,
First, make sure that the wireless network capability ofthe U-Verse RG is diabled (since you're using the Linksys for that purpose).
Second, make sure the ethernet cabel from the back of the RG connects to an LAN port on the Linksys (NOT the Linksys's WAN port).
Finally,disable the DHCP feature on the Linksys (since DHCP should be active on the U-VerseRG). Here's how:
1) Install the Linksys software on your computer and open your internet browser.
2) Type the URL 192.168.1.1 (default for Linksys access ponts).
3) You'll be asked to enter a username and password. The default is username "admin" and password either "admin" or [blank].
4) Once you've logged in, scroll down on the basic settings page (the one that loads automatically) to where it says Network Address Server Settings (DHCP). Click the radio button next to Disable, then click Save Settings at the bottom.
What you've basically done is make the Linksys another computer in your network, and the one that others will connect to the RG through.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
Wi fi light is not on
www.peplink.com/technology/4g3g-modem-support/
https://forum.peplink.com/
Apr 17, 2014 | Peplink Pepwave MAX BR1 4G LTE router- for...
Setting up edimax EW7303HPn
Hello, my name is Glenn, I am not familiar with wireless signal boosters, but I have a great idea on how to set up networks and multiple routers in 1 network. How I picture a wireless signal booster to work is to plug in from your netgear router, into the Edimax.
Apr 16, 2014 | Edimax Computers & Internet
Is there a WIFI Signal Booster out there for a Westell A90-750015-07 Router/Modem?
you don't need a signal booster. Instead what you need is a WIFI signal repeater. This device basically captures your router's signal and repeat it to other devices. Basically place is somewhere between the router and your computer.
There are many out there but here's a cheap one on ebay
http://www.ebay.com/itm/like/122201090687?lpid=82&chn=ps&ul_noapp=true
Apr 12, 2017 | Westell Wirespeed Computers & Internet
How can I boost the signal on my rocketfish bluetooth adapter?
There is no BOOSTER to do it,but you can do it for a router.Depends on your route rmodel there is several router signal boosters online.
Shopping results for wireless router signal boosters z 3 pack Wi-Fi Wireless Antenna / Router Signal Booster
nav_logo29.png 4 reviews - $10.02 - Amazon.com 2 pack Wi-Fi Wireless Antenna / Router Signal Booster
$7.99 - Buy.com 2 Pack Wi-Fi Wireless Antenna / Router Signal Booster
$8 - 2 stores
Dec 23, 2010 | Rocketfish Bluetooth USB Adapter...
ERROR 203 on MEIKO MODEL D 120.2
error 203 means , no change detected by the level switch when draining . possible cause
1, booster pump faulty
2, booster pump plug connector loose
3, start capacitor faulty
4, plug connector loose
5, boiler level switch faulty
6, no boost pump signal to- i/o pcb
7, no "boiler full" signal from i/o pcb check booster pump/ s2with manuel control
the most lightly or most common is the level switch in boiler tank will need changing
Jan 21, 2009 | Meiko FV 130.2 Dishwasher
Cannot get the router to broadcast wireless
Check for a firmware update @
http://www2.verizon.net/micro/actiontec/actiontec.asp
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2008 | Actiontec GT704WG Wireless Router...
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
