My quantum 06series-q logic 2 went into idle mode and now the screen is flashing a white screen I have tried everything please help sos
3 Suggested Answers
ganeshkhatri
  • 173 Answers
SOURCE: my blackberry pearl 8120 just went black out on
This might happen's because of the Handheld software might got corrupted. Kindly reinstal the software of the Bkackberry Handheld, Still if it is not working please walk into the service center.
Posted on Nov 11, 2009
budmrtn
  • 11361 Answers
SOURCE: Monitor went white screen.
Is it model VX2235? The VX series are known for bad caps problem, http://s807.photobucket.com/albums/yy352/budm/VIEWSONIC/Viewsonic%20VX2235W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 01, 2011
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue...
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Dec 12, 2010 | Panasonic TH-42PX60U Television
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
May 14, 2010 | Panasonic Televison & Video
Screen went white
The white glow with no picture means that either the ribbon cable connection between the logic board and the monitor has come lose or dirty contacts, or the LCD Controller (T-CON) board (part of the LCD panel is not getting 5v or 12v depend on LCD panel from the logic board or the LCD controller board has blown fuse, see pictures here for guide (note pin on the LCD board with arrow mark is pin 1 and is the incoming DC power supply line): http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/?action=view&current=DSCF0881.jpg
You may also want to look for bad caps (bulging top) on the logic board. There should be 5vdc feeding the logic board also.
Mar 31, 2010 | Envision G918W1 Monitor
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
WHITE SCREEN
first make sure its not the monitor... connect bad one straight to the video card and see if u get video if so then check, control panel / display / settings, are you still multiple monitor mode? try and identify also
Jun 01, 2009 | AOC 5 En 15" CRT Monitor
Screen flashes colors then turns off
Check connector between Logic & PSU 2nd pin from Left (Vs_ON) for DC volts.
If Voltage is 0 then problem is with Logic or SSB.
If Voltage is 3.1 VDC then problem is with PSU or other PCB's on Panel.
On startup Logic checks for errors and also polls the SSB for Errors. If Errors found then Logic will not send High to PSU.
To confirm if SSB or Logic is at fault then disconnect and remove SSB.
Use 2 Jumpers to short J8003 & J8004 on the left edge of the PSU
Use 1 Jumper to short CN2012 on the lower left part of the Logic PCB (White signal to the Display).
Plug in the AC to the PSU thru CN8001.
If PDP panel operates with White field screen then problem may be the SSB.
Jan 23, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Black Screen
DISPLAY HAS POBABLY WENT BAD.
BUT THE WAY TO MAKE SURE IS TO CONNECT YOUR COMPUTER TO A DIFFERENT MONITOR TO SEE IF YOU GET THE SAME RESULT
Jan 16, 2008 | Sony VAIO VGC-V617G PC Desktop
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
