Question about GE Profile 30" Self-cleaning Freestanding Electric Convection Ran True White
The bottom heating element is not working. How much is the element and is it able to be replaced?
MD# BP260F1AD S/N# TM284894
  • GE Master
  • 473 Answers
Your model number is not complete, I think it should have a J added to the front. If I'm correct on that guess your bake element is part # WB44X5082 and should retail around $35.00 give or take a few dollars. Unplug range or shut off breaker first, Remove 2 screws, 1 on each side of the metal plate at back wall. Pull old element forward gently. There will be 2 wires attached to the element terminals either with 2 more screws or they may just push on depending on which model you have. Remove wires but make sure they don't go back into the cutout. Install wires onto new element and remount to oven wall with the first 2 screws. If wires somehow get lost back in that hole you will need to pull out range to get to the back cover plate and the wires. Not hard at all if you are somewhat handy. Make sure screws are tight if they hold on the wires.
Posted on Apr 17, 2015
    Top Expert:
  • GE Master
  • 45,294 Answers
No idea of price but yes replaceable by a service tech
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Tappan Oven 316246653. Preheating the Oven does not work. Bottom Heating Coil (if thats what its called) is not working. The Broiler Coil at the Top does work. Is it the bottom coil that needs replaced...
Usually when the element fails to heat up, It means its usually broke, cracked, or where they plug in gets brittle and breaks. Your best bet is to replace the bottom element.
May 23, 2011 | Microwave Ovens
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Burners are working oven is not working ?
The heating element may be burnt out, you will need to replace this element if it does not heat up when the oven is turned on, try turning the oven to broil if the top element heat up then indeed it is the bottom element and need replacing.
Dec 18, 2009 | KitchenAid KESC300 Electric Kitchen Range
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Bottom Element Open Circuit & Fan Element not working
No resistance in a bake element is a bad element. Replace it.
Most fan come on with a rise in heat. No heat/no fan.
Apr 08, 2009 | DeLonghi Ovens
The heating element on the bottom of the oven does not work.
lots of those old elements are still out there...some come out with simple pull...or two screws holding the wires!.. take to appliance store (sometimes even lowes!)
Mar 15, 2009 | Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile 30" Self-cleaning Freestanding Electric Convection Ran True White Logo
127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
