Question about Bosch 1998 98 Mercedes Benz ML320 Alternator-1998 Mercedes Benz Alternator
Thortle bodt installed car start but don't open
There is a box on the front valve cover with a cable running out of it towards the throttle bodt on my 2.5 liter, what is this box?
we need more information like year make model of what vehicle you are talking about either repost or edit request
Aug 30, 2016 | 2001 Mazda MPV
New thortle body installedvehicle start but don't go
Electronic throttle? replace the TPS.
Apr 17, 2015 | Cars & Trucks
Ran out of gas. Put more gas in, and it wont start. Is there a reset switch?
check your fuel pressure if it has the CPI injection pressure should be 58-65 psi with key on engine off.If your motor has the TBI throttle bodt injection your fuel pressure should be 9-13 psi with engine running.
May 06, 2011 | 1994 Chevrolet S-10 Blazer
I changed the plugs and wires and distributed cap and rotor button it starts up good.but will not thortle up
Not calling you dumb but I have been a mechanic for over 25 years and have messed up the firing order even though I "thought" I did it one wire at a time. I would double check my firing order for starters if I was you. It may be that simple and I hope it is for your sake and good luck.
Mar 30, 2011 | 1994 Nissan Pathfinder
Hard to start when cold. won't hold idle speed, just shuts down
make sure thortle body is clean, it also sounds like the idle air control valve is not working may need replacing, this is what hold the engine at idle,mostly when first started ,but also at other times when requested by computer to raise or lower the idle, hope this helps good luck.
Oct 22, 2009 | 1997 Dodge Ram 1500 Club Cab
Engine cuts out when thortle is pushed foward. 1996
high speed jet in carb is clogged, thats why its fuel starving under a load. 99.9 percent sure a carb cleaning will fix your problems.
Jul 14, 2009 | Boating
Dcr dvd 306e camcorder where can i buy flat flexi cables
hi, from here you will get replacement of flat flexi ribbon cable for your camcorder http://judy-hydigital.diytrade.com/
May 29, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
Bosch 1998 98 Mercedes Benz ML320 Alternator-1998 Mercedes Benz Alternator Logo
290 people viewed this question
Top Bosch Electronics - Others Experts
Mike
ray gallant
Are you a Bosch Electronics - Other Expert? Answer questions, earn points and help others
