Question about Vehicle Parts & Accessories
Location of expansion valve in ac system in 1996 Nissan hard body
    Sergeant:
  • 295 Answers
Inside the black box behind your dash on passenger side behind glove box
Posted on Apr 17, 2015
Location of Expansion valve on 2001 Monte Carlo. Trying to find where it is so I can replace the AC system
the expansion valve (TX valve) is located at the inlet pipe next to the evaporator
Jun 25, 2017 | AC Cars & Trucks
Where is the ac expansion valve located
The expansion valve is always located at the evaporator core inlet and outlet pipe.
Jul 27, 2015 | AC Cars & Trucks
Where is expansion valve located
The Expansion valve is located in the evaporator box
On this year Nissan it's not to bad of a job. The dash doesn't need to be removed like the newer cars.
  1. To replace the expansion valve, you will need to discharge the AC system. Remove the two AC lines from the evaporator.
  2. Then you will need to remove the glove box
  3. Then you will need to unbolt the evaporator box
  4. Tip it back and remove.
  5. Once you have the evaporator box removed, then you can replace the expansion valve. I would also clean the evaporator box as well since you will have it removed.
May 20, 2015 | 1998 Nissan Sentra
Replace ac expansion valve
t isn't necessary to remove the wiper or the false bulkhead cover. the valve is accessible in the engine compartment with simply removing the air collector and air box. These instructions had me baffled because all i was exposed to when i removed the wiper system was the cabin fan. The valve is located on the passenger side directly under the power steering rack. its hard to see right off, so if you have a hard time
finding it, locate the large and small medal pipes and follow them to the firewall and you'll see the valve. After finding it, it took about 30 mins
to replace.
Expansion valve removal STEP 1 Drain the the AC system (Depending on the car)
Aug 23, 2013 | Saab Cars & Trucks
Where is the expansion valve located on the 2004 KIA Sedona
Kia Sedona expansion FRONT valve located under dash, behind glove box, fan and coil. Evacuate freon first. Disconnect Freon lines from firewall., Lay right front seat back to flat horizontal position and lay on top or totally remove the seat for easier working access. Remove under dash cover, fan, glove box, coil housing, remove coil mounting bolts, remove old expansion valve. (Inspect old valve, if debris inside, blow out coil before installing new valve. If visible debris best to consider replacing REAR expansion valve and DRIER/FILTER in front of radiator too and blow out all lines and coils while servicing.) Use compressor oil to lubricate "O" rings on new FRONT or REAR expansion valve, install valve bolts, reinstall coil bolts to FRONT firewall or REAR frame, reconnect freon lines to firewall in engine compartment. Evacuate AC system, install freon (35 1/2 ounces, nominal 3 pounds), check system for leaks, check for proper operation, enjoy.
Sep 12, 2012 | 2004 Kia Sedona
I am looking to convert the AC over to 134a. I have heard that the oil, the dryer and the expansive valve need to be replaced and then the system vacuumed out. where are the expansion valve and the dryer...
Look for the expansion valve where two of the AC lines connect together, usually near the radiator and the lines may be slightly different diameters, the larger one contains the valve. It is also VERY important to flush ALL of the old oil out of the system. Do this with an AC flush kit and all parts removed. Concentrate on the condensor and the evaporator after the hoses are flushed. Coat all 'o"rings and seals with AC oil when reassembling and be careful, leaks can happen and will be costly. Install 1/3 of system oil capacity in compressor and TURN the compressor by HAND after hoses are installed to it. OIL DOES NOT COMPRESS!! You may want to have a shop evacuate the system when ready.
Sep 01, 2011 | 1991 Nissan Stanza
I cannot find the ac expansion orfice tube in a 96 pontiac transport or the location of the expansion valve
LOOK FOR THE ORIFICE TUBE SHOULD BE LOCATED IN THE SMALL REFRIGERANT LINE GOING INTO EVAPORATOR INTO THE FIRE WALL.
Aug 08, 2011 | 1996 Pontiac Trans Sport
How do i change the expansion valve on a 1996 nissan pathfinder? its not under the hood unless once the hoses are removed it can be pulled thru the firewall.. very little cool and it goes away fast,...
you have to remove the glove box and take the section just left of the blower motor out of the hvac box. the expansion valve is located on the side of the evaporator.
Jul 14, 2011 | Nissan Pathfinder Cars & Trucks
Where is the expansion valve located on 05 altima
Your expansion valve should sit between the drier and the evaporator, right in the firewall connected to the evaporator. Good luck RJ
May 13, 2011 | 1996 Nissan Altima
Need to find the location for expansion valve on honda accord lx 1996
expansion valve is located inside evaporator box behinde glove box you will need to evac system and recharge if going to replcace...this job is not for the first time mechanic
Jul 03, 2009 | 1996 Honda Accord
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
