Question about Timex Watches
How to restore the total callendar after the battery replacement of my watch Timex T3C321?
  • Timex Master
  • 18,394 Answers
Try this link below
http://assets.timex.com/manuals/
Posted on Apr 17, 2015
Testimonial: "Thank you,I will try the link."
  • Lusa Nobre de Oliveira
    Lusa Nobre de Oliveira Apr 17, 2015
    In link above, they don`t write about the watches with two recessed push buttons.
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
SOURCE: Timex Expedition watch
I bought this for my son and he has been living with it for 4 months, and hour and ten min. off !  I just want to set the time, and I'm at the top of the world, no radio shack down the road.  Turn right at the polar bear.
Posted on Oct 14, 2007
SOURCE: have timex watch had battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Posted on Jun 15, 2009
SOURCE: How do you replace the battery on Timex Women's Rush Watch?
Hi All,
I received an email from Timex customer tech support to take it to a jewler which pretty much means buy a new one. Not worth the cost of the battery and repair. I have the tools so I might as well try it myself. Either way, I will either fix it or buy another watch.
Thanks,
Sandy
Posted on Jul 01, 2009
  • 183 Answers
SOURCE: I have a Timex Indiglo watch that I
This watch will have what is called and "AC" or All clear to reset it. There should be a white sticker with very small print on the back lid that will walk you through doing this procedure. It typically involves pressing down a tiny lever onto a small metal pad that will reset the watch.
Posted on Sep 17, 2009
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How does one replace the battery used to power timex rush T44361
Hi Debra, yours might be similar to my IronMan watch...... 4 small Philips head screws to remove then back comes away to reveal a sticker that has 2 clips either side, use a safety pin point to release the clips and the battery comes off with the sticker! The battery is placed with the total flat side upwards! Hope this helps!
Nov 01, 2014 | Timex Indiglo Watches
No sound
If you lost the spring, I can't help. But repairs like this SHOULD be done carefully on a mat or table to help contain parts. My Timex watch made no sound after I changed the battery. I was unsure what the internal plastic sheet meant when it set something like short to reset. BUT, as shown elsewhere on this FixYa site, simply turning the back cover 180 degrees restored the sound, and the watch works great again!
Sep 03, 2009 | Timex 50-Lap Ironman Triathlon 59221 Wrist...
How do you replace the battery on Timex Women's Rush watch? I searched their site to no avail and sent an email to their tech support. Replacing watch batteries was fairly easy for the dexterity challenge...
Hi All,
Thanks,
Sandy
Jun 29, 2009 | Timex Rush Sports Watch
Timex electric and dynabeat wrist watches
Good day Sir, If you own a Timex and it seems to be running a little slower than usual, visit the link below for their manufacturer watch battery replacement services.
replacement batteries
Mar 13, 2008 | Timex 27191 Wristwatch
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Watches Logo
210 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
