Question about Garden
How do I lower the rpm's on a pacific hydrastar pressure washer engine.
    Top Expert:
  • 10,875 Answers
Adjust the governor,not the set screws on the carb
Posted on Apr 17, 2015
Manage my life com sears
the pump is direct drive from the motor
it is not designed to be disengaged
by lowering the rpm, it will decrease the pressure a little bit .
Jul 07, 2014 | Honda Black Max 2600 PSI Pressure Washer
Engine racing very high when pump not using
Sounds like the engine governor is out of adjustment or it is sticking. The engine governor job is to regulate the engine RPM and torque that is needed to power a load and return to the manufactures no load engine RPM. Recommended RPM's on pressure washers and generators are usually governed at 3,600 RPM's because that is where the engine is producing most of its torque and HP.
Mar 10, 2014 | Honda Garden
2005 Dodge Neon Oil Pressure light flickers at 1000 RPM or lower
check oil pressure switch located on side of engine block. not sure what side on a neon.
Nov 16, 2012 | Dodge Cars & Trucks
My Generac pressure washer will work great for as long as I hold the trigger. If I release the trigger to move something or change positions and then pull the trigger again the pressure doesn't come...
Sounds like the unloader valve built-in to your system is sticky. Try lowering the pressure of the regulator to lowest setting then re-adjusting. This will place a different pressure /load on the valve. Also when you store your unit, displace the water in the pump with oil so that lubricant will prevent the unloader from sticking. If you continue to have problem, replace the unloader. Good luck
Jun 30, 2011 | Briggs & Stratton Power Products 1539...
Hi. I'm scratch building a pressure washer using a Comet BXD2831G pump. If I don't plan on using any type of detergent, is it OK (or manditory) to plug the detergent intake to keep it from sucking...
No need to plug the injector because under pressure (internal force/pressure) keeps valve shut. It only opens when large nozzle (black tip) is used lowering internal pressure causing siphon effect. Some chemical injectors have a thumbwheel to shut off flow completely. Your plug idea will keep the opening clean for later use. You can adjust pressure by ear. Your pump will take a 6.5 hp engine to develop max pressure of 2700 psi, however, to extend the life of the pump and engine, adjust pressure to about 75 % of capacity or about 2000 psi. To develop 6.5 hp your engine must turn at about 3600 rpm which is over the max rpm of the pump 3400rpm. The rpm of the engine is usually set by using the appropriate governor spring. Easy task, by using the model number and type of the engine, you can determine the proper governor spring and placement on the throttle arm, maybe about 3000 rpm would be sufficient. Now with engine rpm set, turn pressure adjustment up until engine sounds to you like at full labor, then adjust down to a workable pressure for majority of work and turn up for stubborn debris. Good luck with your project.
May 31, 2011 | Comet GXD2527G Pressure Washer Pump
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Have a 11hp power washer pump not sucking water, how do i fix ?
Hey there...
Is the washer a direct drive or belt drive unit? If it is a direct drive ( the pump bolts directly to the engine) then the pump needs to be force fed the water, either by city pressure or a transfer pump. If it is belt driven, the lower rpm's should pull water, so more detail would be needed...
Feb 01, 2010 | Honda 8 HP Engine
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Nov 20, 2009 | Garden
No Pressure
is the engine still turning up good or does the press. fall when engine rpm drops? your not very clear on this.if the engine is dropping rpm there is several problems causing this and without being able to actually see and hear what is going on there's no way i can go thru all that could be wrong.
Jul 09, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
