Question about Dryers
Push the start button and the dryer starts but will not stay on. Hold button in and dryer runs as suppose to. Whats wrong?
Electric, heating units work
    Top Expert:
  • Dryers Master
  • 10,875 Answers
Switch or relay is bad
Posted on Apr 17, 2015
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
When I push the "push to start" button (knob) on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 14, 2011 | Kenmore Dryers
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Kenmore Electric Dryer M#62932
Check the door switch on the unit. The unit will not run if this switch is bad. Also, the thermal cut out needs to be tested as well. While you are at it, is the element bad? These are some things that can cause the unit not to run.
Apr 10, 2009 | Dryers
Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Jan 30, 2009 | Kenmore 67082 Electric Dryer
Dryer not working
the button you push is a momentary start switch.whats suppose to happen is the power passes thru the push to start switch for a moment till the motor centrifugal switch goes to the run winding.what i have found happening is a lint buildup in the motor switch area dose not allow the motor centrifugal switch to reset to the start winding when the dryer has finished the last load.so its trying too start on the run winding and it could only do that if you helped by spinning the drum while hold the start switch.soooooo.... unplug unit .get to the motor and vacuum it out.inspect your wiring for burnt/loose connections.if all is well and vacuuming did not solve problem.your motor may have an open start winding which you could check with an ohm meter.if you need any more help you can make an request thru fixya email. God bless ,tom
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Open Questions:
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
