Question about Watches
How to restore the calendar after battery replacement?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
If you have an analogue watch(one with hands) just pull the stem half way out and you should be able to set day/date.Date Reset
Pull the crown slightly outward and stop in the middle position. Do not pull it all the way out. Once you've stopped in the middle position, turn it quickly either way. The date display will change temporarily without affecting the proper date setting.
Pull the crown out all the way and set the time. Once time is set, the date will automatically be displayed accurately.
Sponsored Links
Download This To PDF
Its Free To Download and Convert. Get It In Seconds. Download Free.
fromdoctopdf.com
Push the crown back to its original position when done. The perpetual calendar will be reset and the date should now be accurate. According to the Timex manual, this often happens accidentally when the crown is pulled out to the middle position, but for these purposes it can also be used to reset the date on the calendar.
Time and Date Reset
Pull the crown all the way out and turn to the desired position until you set the time correctly. When the time is adjusted past midnight, the day and date will change automatically.
Check the time and date to make sure they are both correct. If you set it at midnight rather than noon, set the time 12 hours ahead or back to match the actual date. You can determine this by observing whether the date changes at 12 o'clock. If it does not change, it is set at noon; if it does change, it is set at midnight.
Push the crown back to its original position when done. The time on the watch and the date on the perpetual calendar should both be accurate now.
Read more : http://www.ehow.com/how_7436826_reset-timex-watch_s-perpetual-calender.html
Posted on Apr 17, 2015
Testimonial: "Thank you, Andrew Martin,but I have a Timex watch with perpetual callendar (model T3C255) and I can not be able to set day of the week and the month."
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
How do you replace battery
only timex watch technician is changing the battery of a timex perpetual calendar because the date must be calibrated so that it works properly again...
Jan 11, 2013 | Timex 2G561 100 Meter Watch
Might light no longer works, had battery checked and it is fully charged. Please advise
the indiglo of your watch is probably busted, you had to replaced its dial. the the battery has been checked but not the watch by a new battery? try to check the watch by a new battery. if still not lighten up check the connection of the button it probably cannot connect the connections of the light. i hope this advise will help you a lot.
Sep 08, 2011 | Timex 2D421 Stainless Steel Perpetual...
I took the back off to replace battery and now I cannot get the back on the watch
You have to bring it to watch expert, because they have pressing tools to close it.
Jul 10, 2011 | Armitron Calendar Date w/ Case, Dial and...
Needs battery replacement
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here's my suggestion. Take it to the jewelry dept at Walmart. Do you have one where you live.
They'll replace for free - Battery $8
Watch how they do it with their tools and you'll know how to do it yourself in the future.
Good luck
Dec 12, 2008 | Oakley GMT OAK0531 Wrist Watch
Watches Logo
35 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
