Question about Car Audio & Video
I used a fuse too big for my amp and it stopped working after extremely overheating
The power light comes on and the amp gets hot
  • 2 more comments
  • Luke
    Luke Apr 17, 2015
    No and its not like i didn't know either FML too many beers.
  • ray gallant Apr 17, 2015
    there has to be an internal short . so get out the tester and get started or live on without
  • Luke
    Luke Apr 17, 2015
    I did and I'm getting .10 power from the speaker out puts when i shouldn't be getting anything. Don't really know what i'm looking at though... Is it worth fixing? I have 2 w5 shallow mount 13.5's what would you suggest using?
  •  johnny rebel
    johnny rebel Apr 17, 2015
    you have fried it,take it to get repaired or junk it.
    Sergeant:
  • 295 Answers
If I were you and also not briIliant would have just bypassed the fuse and hooked it directly to the car battery....now ....you get out there and go buy another one ...and match the rms on amp to the rms on speakers...your welcome..now get outta here you knuckle head
Posted on Apr 17, 2015
    Sergeant:
  • 337 Answers
Yep fried
    Top Expert:
  • 10,875 Answers
It is fried because you cared so little for it that you used the wrong fuse
  • Luke
    Luke Apr 17, 2015
    Worth fixing?
    Top Expert:
  • Car Audio & ... Master
  • 52,086 Answers
What did you expect for it to work forever.
2006 kia sportage hot-temperature gage went to extreme hot & stayed there, then dropped to all the way cold/checked oil & it was hot/almost smoking. car started but then quit. not fixed yet.
Unfortunately for some personal reason, you chose
to use your vehicle, knowing the coolant was being lost.
You should have have it checked out when you first
noticed any problem & now you have run the motor
low on coolant,overheated every fluid
The cause!! Could very well be you have a bad head
gasket & not thinking you had a serious problem
Now you do & it will be an expensive repair,involving
fees for testing, to find the issues & no way to know
the possible damage to the engine & especially the
cylinder head,to the point you may need a complete
reman motor, if the damage is bad enough to make that the best solution
Unfortunate, as I consider a 2006 a fairly new vehicle,especially
if you bought it new.
Lesson learned the hard way
Fluids start to go away,stop using it
Don't change Transmission & Power Steering
Fluids every 3 years-they will fail,fluid breaks down
& no one changes them
Don't change motor oil every 3 to 4,000 miles,
other issues on some vehicle. that's 4 to 5 times
a year,alot of your time & expense,but it has to be done
on all vehicles,brake fluid every 2 years or more rust,
& moisture in that system & big repair bills.
You could have a bad thermostat stuck closed or an
easier to solve & less expensive repair to make,but you
cooked that motor,so be aware of that
Jul 21, 2013 | Cars & Trucks
My peugeot 206 keeps cuttin out and the enguin light comes on while im driving it started off only doin it a couple times now its doin it often it seems to get hot quicker than normal 2. its ok if i am...
SOUND LIKE ENGINE OVERHEATING,CHECK COOLANT LEVEL MAKE SURE YOUR RADIATOR FULL OF ANTIFREEZE.IF YOUR COOLANT OVERFLOW JUG IS EMPTY COOLANT LEVEL IS LOW.NEED ADD MORE COOLANT TO OVERFLOW UNTIL COOLANT STAY AT FULL COLD MARK. DONT OVER FILL COOLANT OVER FLOW JUG.IF COOLANT OKAY ENGINE OVERHEATING REPLACE THERMOSTAT.MAKE SURE ENGINE COOLING FAN IS WORKING IF YOU COME TO A STOP CAR SITS FOR A LITTLE WHILE START OVERHEATING THE COOLING FAN NOT TURNING ON , BECAUSE COOLANT FAN FUSE BLOWED OR YOU HAVE BAD RELAY,THE ENGINE COOLANT TEMPERATURE SENSOR FAULTY.IF YOU HAVE THE CLUTCH TYPE COOLING FAN, MAKE SURE WHEN TURNING CLUTCH FAN WITH HAND COOLING FAN SHOULD HAVE RESISTANCE WHEN HOT.IF CLUTCH FAN FEEL WOBBLY AND LOOSE REPLACE IT.TAKE VECHICLE TO AUTO ZONE OR ADVANCE AUTO PARTS OR ANY AUTO PARTS STORES THEY WILL CODE SCAN CAR FREE AND GIVE YOU THE CHECK ENGINE LIGHT TROUBLE CODE TO SEE WHAT CAUSING CHECK ENGINE LIGHT TO TURN ON.
Jul 30, 2011 | 2005 Peugeot 405
Have no power out of the trailer plug 4or 7 prong,where should i look for the trouble?
Not sure which part you mean no power.
For the New Body style 2004 ( not a Heritage or Lightning model )
If both Stop / Turn pins & the parking lamps, might want to check the ground pin to make sure it is good ( or what you are using for ground on the test light / meter ).
The trailer tow parking lamp circuit is fuse #10 to the parking lamp relay
The stop / turn circuits also have fuses on each one, Fuse #36 & Fuse # 42 ( R & L ).
The 7 pin has fuses for the battery charge pin ( hot in run position ) and the reverse circuit ( hot in run & when in reverse ), Reverse is also fuse # 10 to the trailer tow reversing lamp relay & the battery charge pin is fuse # 106 to the trailer tow battery charge relay.
Could be all the fuses are blown, or what you are using for ground on the meter / test light is not a good ground.
Mar 16, 2011 | 2004 Ford F150
TV blew fuse. Replaced with 125v 5 amp from a 33 inch Toshiba that has gone bad. The 5 amp also blew. Purchased new 4 amp fast blow fuse for unit, now nothing happens, i.e., no blown fuse, no circuit...
replacing the fuses with random values is prolly not a good thing...but one thing to check is a big transistor know as the HOT. This will more than likely be clipped or screwed to a heat sink NEAR the flyback (big transformer, has a wire going into the big glass tube). That causes fuses to blow...If this does not work, let me know.
Nov 30, 2010 | Toshiba 13A23 13" TV
Waring Pro Waffle Maker
I posted the same problem (no heat) but may have found the answer. There is a component that cuts off the power if the unit gets too hot. My best guess name for it would be a "thermal fuse". If it goes...no heat. (located behind one the waffle grids inside unit..silver and black)(behind the other grid is what I believe to be a variable resistor that varies with heat..used to set heat levels in conjunction with the dial on the front of waffle maker)
When thermal fuse goes it needs to be replaced. BUT I WONDER
what caused the overheating? I will go down to Radio Shack and buy the "thermal fuse" according to the data on the old "fuse" and put it in...then ????waffles or sparks???
the old fuse has printed on it: sheng ping SPF240 TF240 Deg. Celsius 10 amps 250volts 073 and some symbols
Wish me luck
Feb 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Amp Was Extremely Hot and I Have Now Lost All Sound
Where was the smell coming from? The amp or the sub?
Do you have an ohmmeter to check to see if the sub's voice coils are still intact? Can you try driving the subs with another source to verify they are ok? We need to eliminate the variables here.
If the subs are okay then it's obvious that the problem is in the amp. I'm not sure if there are any protection devices internal to the amp, but I am sure if you remove the cover from the amp and if it was amp that was producing the burnt smell, you'll have no trouble visually identifying where the problem is in the amp. Most likely you'll find a part that is discolored or black & burned.
Usually a smell like this from a solid state device indicates a component has been overheated and if run long enough in this condition will fail.
- Jim
- Jim
Jul 07, 2008 | Alpine 600W Class D Mono MOSFET Amplifier...
Amp is not coming on
the fuse may not be working, you could try a larger sized one, also if you have the old power cable try it again with a larger fuse in place, if it worked before its likely to just be the fuse wasnt big enough, check all the other connections are in the right place, if they all are and you know the amp hase worked before then it could only realy be the fuse isnt big enough or the power lead is faulty.
cheers, adam
Nov 17, 2007 | MTX Thunder TA7801 Car Audio Amplifier
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
AMP WON'T WORK POWER SUPPLY?
that big coil of wires ytou described is the transformer for the switching power supply. Sounds like you over heated it and blew out the supply or the output section. From what you described you should take or send this unit into be serviced as there are no user serviceable parts in this unit except a fudse maybe and if thats blown theres more problems as thats there ( the fuse) just so the whole bloody thing dosent burn up your car! Good Luck
Jun 14, 2006 | Rockford Fosgate Punch 300S Car Audio...
Car Audio & Video Logo
121 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
