Question about Tablets & eReaders
On trio stealth 10 i have to factory reset every few days bc it keeps saying unfortunately google and etc stopped working how do i fix it
Well sometimes when my phone does that which it rarely does i just shut it off for like 20 minutes and if that doesn't work i reset it
Posted on Apr 17, 2015
Can someone help? I have a Trio tablet. I am unable to access due to multiple pop ups that Google has stopped working.
try if you can delete all not necessary files from startup sequence, and if you can download upgrades for the system, if you can, upgrade to android 4.1.
if not then go to this site and try to flush it:
http://forum.xda-developers.com/showthread.php?t=1831257
have look at the flics and follow comments as well:
https://www.youtube.com/watch?v=ZcOqELRABDs
https://www.youtube.com/watch?v=QaGCIItG3NA
hope this will help you - do not forget to vote... by the way, i did find them on amazon for $45.00 new...
Feb 26, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
I have a trio stealth g2 10" and it was stuck on the start up (logo) page. I tried the hard reset (holding -volume and power button) and it worked for a day then froze up again. When I tried another h
I cases like this you might not have a choice but to factory reset to fix the start-up error. Repeat a hard reset (Vol up/Power button) and make an effort to get to the tablet Settings after boot up. Get to the Settings>Backup & reset>Factory data reset. In the majority of cases a factory reset will resolve critical issues. This is thought of as a "nuclear option."
If this nuclear option fails then a more complicated process that's beyond this post is to consider installing a custom Android ROM after rooting the device. XDA has a forum discussing rooting and installing custom ROMs for Stealth tablets: http://forum.xda-developers.com/showpost.php?p=34126848
Good luck.
Nov 20, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My trio stealth 8 keeps resetting it self to defult setting what can i do to fix
Try doing a factory reset. It can be done from the setting menu usually, or via a special button combination. Google will help you if you google your model number and 'factory reset'
Sep 16, 2014 | Tablets & eReaders
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
Sep 14, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
MESSENGER, GOOGLE PLAY, ETC. HAS STOP WORKING
Reset to factory defaults? Not a bad idea if the problem cant be solved with uninstall-reinstall apps
Apr 08, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Android.process.acore
Go into Settings/Applications/All and find Google Services Framework and clear the cache (if any) and clear data.
Disable DRM Protected Content Storage and Media Storage in your Apps list.
Or if either of those fails, uninstall latest update [until you get to the latest properly working update] or factory reset
Jan 12, 2014 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
Tablets & eReaders Logo
64 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
