Question about In Microwave Ovens
Microwave- Sharp R530 ES model sensor cooking is no longer functioning. Press Popcorn it will burn the hell out of the popcorn and make sparks.What part needs to be replaced?
There are not error codes displayed, The microwave functions fine except these sensor controlled buttons. They are the top 6 buttons, all sensor controlled cooking is not functional, it just turns on and sparks or acts like cooking but not. This oven is built in and I would really like to just repair it, its been a great oven.
    Top Expert:
  • In Master
  • 10,875 Answers
A new sensor
Posted on Apr 17, 2015
Power it stays at 100% want 50%
Most microwave ovens I am familiar with have adjustable power levels.
Sep 11, 2016 | Panasonic NN-H765BF 1250 Watt Microwave...
Change spark
Check diode and capacitor. Instructions should be found inside the unit.
Nov 11, 2017 | GE Advantium SCA2001BSS Microwave Oven
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
What should my powerlevel be on on my microwave because it keeps burning my popcorn
Your power level should be on high, but you shouldn't rely on the oven to time the cooking. I have yet to find an oven that won't burn popcorn if it has a preset POPCORN button. Press it and walk away and next thing you know, you've got charcoal. You should always stick around while making popcorn. Stop the oven and take the bag out when the time between pops drops to 1 or 2 seconds. The corn will continue to pop on its own for a bit because of stored heat, but you won't burn it. You'll never get 100% of the corn to pop, so don't worry about unpopped kernels.
Feb 28, 2011 | Emerson MW8777W Microwave Oven
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
No homegrown popcorn in a microwave? why?
Popcorn is a food that has a very low moisture content, and microwave ovens rely on moisture content (water molecules) in order to cook.
If there is not enough moisture to absorb the microwave energy, much of the the energy is reflected back to the magnetron and damage it.
This is also what damages a microwave when it is run empty.
A simple solution is to add about 1/2 to 1 cup of water in a microwave-safe container in the back corner of the oven and cook your popcorn a little longer.
You'll have to experiment a few times to get the combination right for your particular model.
But allow our microwave about 15 minutes or so for the magnetron to cool down between popcorn cooking sessions.
Also, I would suggest putting a paper plate upside-down on the turntable tray, then putting the popcorn container on top of that.
This does two things: It keeps the extremely hot popcorn off the tray, reducing the chances it will crack, plus it raises the popcorn up so it will heat more efficiently.
Dec 23, 2008 | Microwave Ovens
Toaster Master 1979 has less power
Because the microwave energy is beamed into the interior of the microwave and then dispersed by a metallic "stirrer," the pattern of the energy can be fairly consistent, rather than completely random. But this pattern sometimes causes certain portions of the food to overcook (creating tough spots) and others to undercook. A microwave oven with a carousel is far better at cooking the food consistently--the pattern becomes quite random while the carousel is turning.
Nov 13, 2008 | Microwave Ovens
Popcorn
According to the owner's manual (which you can download free from us here),
1. Place the bag of popcorn over an upside-down 9" glass (or paper) plate.
2. Touch POPCORN pad.
It will cook and stop automatically.
If this does not work, you may have a bad humidity sensor or control board, etc. and parts for this model are generally no longer available.
Oct 28, 2008 | Sharp R-9H84B Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
