Question about Garden
Motor will not rotate fast enough to start mower
Bought new battery and plugs also put new gas in mower.ran for 1 minute.now will not start.
  • 2,029 Answers
Pull your spark plug and put a table spoon of gas into the spark plug hole then reinstall the plug and wire then try to start. If it starts for a few seconds and stalls you have a dirty carburetor.
If you have a fuel cup on the bottom of the carb take it off and clean it out also blow the dirt out of your fuel jet which is likely the bolt that holds the fuel bowl on. Make sure those little holes are clear and try that. Most likely that will do it.
Posted on Apr 17, 2015
    Top Expert:
  • 10,875 Answers
Clean the carb,you sucked in the bad gas from before
Lawn mower won't start
likely the old gas is gunked up
remove the screw on the bowl bottom an look for a tiny hole thats plugged going across the bottom of screw.
if no screw an bowl then its just gunked up lines.
May 03, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Can't get exmark mower with Kawasaki motor to start
Have had this problem with the Kawasaki engines and found the starter to be bad. The old starter was turning it over but was not fast enough to start. Have also found weak battery that did the same. The first one I ran into was a FH680 Kawasaki and spent about 2 hours trying to figure it out and it came down to the starter not turning it fast enough. Put a new starter on and started at just the bump of the switch. Let me know if this helps you out
Apr 26, 2014 | Garden
Riding mower won't start
take the spark plug out and see if the engine will turn over then, gas will probably come out of the cylinder cause you flooded it when you turned it over after you get the gas out of the cylinder, put the cleaned spark plug back in and it should start
Jun 03, 2010 | Garden
Bought new battery. It started. I ran it for
Many times the gasoline in the tank and fuel system is contaminated and must be removed and purged, drain the gas tank by removing the hose going to the carb. and draining into a container, then remove the carburetor bowl located on the under side of the carb. dump the gas then replace the bowl. refill the gas tank and start
Sep 06, 2009 | Garden
13.5 OHV B&S won't stay running, blows gas out carb.
Sounds like you have a blown valve. I'm assuming this is a 4 stroke motor, if it was 2 stroke then it would be the reed valves. But either way it's the valves.... unfortunately that will require a mechanic :(
Jul 19, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Mower will not start
Hi
Take the spark plug out and pour a little bit of oil in the cylinder and crank it over without the spark plug in. Make sure ground wire is clean on both ends.
Apr 13, 2009 | Garden
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
