Question about Watts Hardware & Accessories
I have 2 45 watt led drivers how do I wire them together to get 90 watts ?
    Top Expert:
  • 10,875 Answers
Inline,pos to neg neg to pos
Posted on Apr 17, 2015
I have a100 amp alternator and putting 4-130 watt off road lights and the vehicle on it 98 Chevy blazer
Do the maths and talk to an accredited auto electrician but I am sure that the alternator will be too small for what you want to do
the formula is I(amps)= P(watts) divided by volts
4 lights at 130 watts each =520 watts divided by 12 volts =43.3
amps extra for the alternator to handle. AS most alternators currently run at 90% capacity with normal vehicle operations you will need a bigger alternator. I would consider using a band of LED lights as they have more light than the 130 watts will provide and use just a few amps thereby not requiring a new alternator. Do your home work .the price of a new alternator and wiring ,relays etc against the LED lights. More light , lighter bracketry and no relays.
Dec 20, 2014 | Cars & Trucks
How do I remove the watts regulator and wire it direct to the lighting - Hunter Ceiling Fan watt regulator 98480-02
Try this; Wire nut the two white wires together & do the same to the other two wires. You might also find something on youtube if this doesn't work.
Oct 13, 2014 | Hunter Dryers
If i was to change headlight globes from 55 watt low/65 watt high to xenon halogen 90 watt low/100 watt high is there any problems
Most OE factory wiring is marginal as far as amperage carrying capability goes. They installed wiring fine for the stock bulbs and switch. A lot of vehicles send power to the lights..head and running...through the light switch on the dash. This causes it's own problems as switches are the weak link in the lighting system.
If you run 100watt bulbs you will need to power the bulbs via a 40 amp relay switched by the light switch so the switch does not carry the amperage load through it's contacts.
Doing so will reduce the voltage drop to the bulbs as a 2 volt drop will cause the bulbs to be only 75% as bright as they would be with the full 13.5 volt running voltage..
You run a fused wire from the battery or power distribution block to the relay that should be mounted within 6 inches of the closest h/l bulb. Then from the relay to the head light bulb/s. The front and rear running lamps can remain as factory as they are low amperage draw and original light switch will work because you now no longer run power to the h/lamps through the switch.
Search the www for schematics for relay switched lamps.
Mar 12, 2014 | Cars & Trucks
Any problems changing 55 low beam/65 high beam to xenon 90 watt low beam/100 watt high beam
Check the size of the cables coming to your headlight. A higher lamp wattage would require more amperes for the wires to carry.
What does code n153 mean ]
In the future please be more specific about what you drive. So now I'm going to have to guess what you drive.
OK, 2001 Jetta, three-wire airbag plugs, two wire seatbelt plug (passenger side), four wire seatbelt plug (driver's side). Put in different seats. This is to eliminate the airbag light and restore the order: 1. Connect only positives on airbag plugs with a 4.7Ohm, 1/2 watt, 5% tolerance resistors; 2. Passenger side seatbelt plug: connect with a 2.2K Ohm, 1/2 watt, 5% tolerance resistor; 3. Driver's side seatbelt plug: bundle two positives together (in my case, red and yellow), two negatives together (two browns). Then connect with a 470 Ohm, 1/2 watt, 5% tolerance resistor. 4. Use Vag-Com to clear codes.
Aug 20, 2013 | Volkswagen Phaeton Cars & Trucks
I bought a new panasonic home cinema model number sc-pt480eb-k. Its supposed to be 1000 watts but the output it doesn't match that output at all even with all the speakers on. What maybe the cause of this...
Hype on the part of the maufacturer's published specs.
http://service.us.panasonic.com/OPERMANPDF/SCPT480.PDF
Look at the Power Comsumption spec on page 22. "90 watts"
According to this post, 45 watts...
http://reviews.cnet.com/home-theater-systems/panasonic-sc-pt480/4507-6740_7-34024832.html
It would be a miracle indeed to extract 1000 watts of sustained power in any form, be it heat, light, motion or sound from a unit that uses anything less than 1000 watts of electricity, assuming 100% efficiency. Not to mention the dreadful 10% distortion level they use to get that figure.
To say it pushes 1000 watts is dishonest and preys on the gullible.
Apr 10, 2011 | Panasonic Audio Players & Recorders
DX-66V Base CB Radio: i would like to know what i can do with all the ch...
the 66 doesnt have sideband 45 watts is a hell of a lot of power how did you get 45 watts mine does about 20 watts and is loud as hell
May 18, 2010 | Galaxy Radios DX-66V Base CB Radio
I need a 90 watt bulb for my 15 millon candle watt
Check Home Depot, they should have it, if not in the store then online
Oct 08, 2009 | Vector 3 Million Candlepower Rechargeable...
I would like to upgrade the speakers of my ford 6006cdc Can anybody give suggestions on this thanks
kicker or rockford for subs. hifonics, power acoustics, kenwood for amps. pioneer or alpine for cd deck.
Jul 19, 2009 | Car Audio & Video
Hardware & Accessories Logo
80 people viewed this question
Top Watts Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Watts Hardware and Accessory Expert? Answer questions, earn points and help others
