Question about Troy Bilt 175HP Manual 42" Riding Mower
Gas keeps getting in with oil what is wrong what do I do
  • Troy Master
  • 1,169 Answers
Normally this caused by a leaky float needle valve in the carburetor; although, if you have a vacuum operated fuel pump it internal may ruptured.
Posted on Apr 16, 2015
  • 32 Answers
Usually is a bad float valve needle and seat in the carb. Sometimes dirt in the floatbowl will cause this too. The correct thing would be to replace the needle and seat in the carb.
A temporary fix would be to turn the gas supply off from the tank as soon as you are done using it. If your mower doesnt have a shut-off valve, you can buy one and install it, pretty simple fix.
Posted on Apr 13, 2016
How can I cheat the Idle up? I'm getting a low oil pressure light at Idle, 800 RPM. I would like to increase the Idle to 1000 to keep from getting the light.
that wont work trying to adjust idle can be done on older cars with a carburetor or the older throttle bodies new vehicles trying to do it will set off check engine lights on most sensors sound more like oil worn out---oil filter or pump problem change oil and filter and do a flush ---and put in an additive such as lukas - royal purple etc---also why did head need replacing was oil pump tested
Aug 02, 2016 | 2006 Suzuki Forenza
Baxi back boiler keeps gurgling and rumbling then knocks off any help please
Gas or oil if oil when was the last time you had service on the unit? If reasonable amount of time probably wrong nozzle you want more info need to know what type of boiler gas or oil e mail me at vschnittert@gmail.com I can probably walk you through it
Apr 02, 2015 | Heating & Cooling
Oil in my truck smells like gas
sounds like a head gasket problem.hope not,a big job.the coolant and the oil are meeting through a crack or split in the engine.again hope im wrong but would need attention soon
Mar 12, 2013 | Chevrolet Chevy Cars & Trucks
Why do I get oil on my spark plug?
is it a 4 stroke with an oil pan or a 2 stroke with mixed gas and the plug is getting fouled? if it is a 4 stroke, then it should be stored flat. if it is a 2 stroke that is fouling the plug then it will be a carburetor issue
Mar 02, 2013 | Garden
What is wrong if it will not idle
It would help to have engine codes but it sounds like leaking injectors hard to start because any time the key is on gas is just running into the engine. No idle to much gas. Oil level high because of gas in oil going past rings could blow oil pan off. High speed fine. replace injector or injectors. Look down throttle body with key on and see if gas is leaking out. If this help someone please rate it
Dec 20, 2011 | 1997 Jeep Grand Cherokee
Saw starts but wont build up any power it fouled two plugs back to back do i have gas mixture wrong
sounds like a rich mixture stihl and huskvarna oil has the same makeup dealers have test tubes for warranty service that tells them what oil was used and will not warranty if wrong oil is used with the proper oil your saw will last for a long time cheap oil does not have the additives needed too keep rings free and inhibit carbon buidlup
Jan 19, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
My weed eater wont turn on it keeps turning off as soon as turned on it is really frusterating sorry if i spelled that wrong
Most two stroke engines in weed eaters require a premixed fuel combination of gasoline and two cycle oil. I am assuming you have a gas model which needs a gas and oil mixture. A possible problem is the choke is turned on, and once it starts you need to move the choke to run. Another possible problem is the gas oil mixture is incorrect, and you may need to remix the fuel to the manufactures recommendation.
Jul 23, 2010 | Garden
Go to put n gear and clutch clutch doesnt work
your clutch cable is adjusted wrong, adjust per your owners manual
Jun 27, 2010 | 2005 Honda CRF 250 R
How do I keep getting gas mixed in with my oil?
Does the blazer run ok? how much gas is in the oil? You will get a certain amount of gas in oil thats normal. If your getting like a half a quart thats not normal. If your getting a lot in the oil its got to be flooding and fouling plugs. Need the whole story in order to help. Just taking a gess hear its the injection system, there was alot trouble with them thru the years like your blazer.
Feb 13, 2009 | 1997 Pontiac Trans Sport
Troy Bilt 175HP Manual 42" Riding Mower Logo
104 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
