Need assistance installing the boot on a front load may tag washer.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Turn inside out into drum to get at other clip
Posted on Apr 17, 2015
3 Suggested Answers
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
Jahn27
  • 1554 Answers
SOURCE: I need instructions on how
Disconnect power supply to unit then remove 2 10mm screws from washer back.
Slide the top cover towards the rear to clear the screw head from flange on the bottom side of the top cover.
Pull the dispenser drawer out completely then remove five screws attaching console as shown. Roll the console down and lift it away from washer.
Open the door then expand the boot clamp spring located at the 6 o'clock position and remove the boot retaining clamp.
Pull the boot from the lip formed into the front opening then remove the four screws attaching the top of the front panel to the cabinet.
Lean the front panel forward then disconnect the wire harness to the door lock and switch assembly.
Lift the front panel off the bottom brackets and move it out of the way.
Loosen the boot clamp at the 12 o'clock position then remove the **** and the boot.
Install the new boot aligning the index tabs on it with the screws on either side of the fill tube.
Secure the boot with the clamp then reconnect the door lock and switch assembly harness and reinstall the front panel. Put the boot over the outer lip of the door opening then secure it with the boot retaining spring. Reinstall the console and the top cover in reverse order of the removal steps.
Please make sure to accept the solution should you find it helpful. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 03, 2011
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
How to clean frigidaire front loading washer
In order to provide you the correct instructions on how to clean your Frigidaire washer, I would need your model number please? You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you. - Z
Sep 04, 2014 | Frigidaire Washing Machines
What is the drum size of the washer?
Hello Friend, that's a great question!
In order to provide you the correct drum size of your Frigidaire washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front as you open the door if you have a front load washer. If you own a top load washer, you may find the serial tag inside the lid, on the right side. Thank you and I look forward to your response.
Jul 24, 2014 | Frigidaire FWSB5700DS Top Load Washer
Bleach dispenser
Hello friend, I appreciate your post!
I understand your having an issue with the bleach dispenser of your Frigidaire front load washer. I would like to ask a couple of additional questions to better assist you. Is it not dispensing bleach? If you add fabric softener does it do the same thing? Finally, what is your model number so I may be able to proceed further? Normally you can locate the serial tag (which lists your model number) on the upper front of the door frame. Thank you for the post and I look forward to assisting you. -Matt
Jul 22, 2014 | Frigidaire GLTF1670A Front Load Washer
How do I get a belt for my fridaira bottom load washer and how do I put it on?
Good Afternoon Friend, I am happy to assist you!
Most parts can be purchased directly from the manufacturer or through a parts distributor in your area. With your model number, I can double-check the correct part number for you and/or you may visit the manufacturer website for a comprehensive listing of appliance techs in your area that can assist you with the installation of your new belt. You can normally find the serial tag on the upper front, as you one the door on a front load washer. If you have a top load washer, you can locate the tag inside the lid, on the right side. Hope this helps!
Jul 15, 2014 | Frigidaire Washing Machines
Where is model number located
Good Morning Friend, thank you for your question!
I see that you are inquiring the location of the model number on your Frigidaire washer. The serial tag, which lists your model number, is typically located on the upper front, as you open the door on a front load washer. If you have a top load washer, you can find the serial tag inside the lid, on the right side. I hope this information helps to some degree. If I can be of further assistance, please feel free to reconnect.
Best regards! - Z
May 19, 2014 | Frigidaire Washing Machines
Weight sensor broken in electrolux washer
Hello Carol, I am happy to assist you!
Generally speaking, washers do not have weight sensor. What exactly is the issue your washer is experiencing? May I please have the model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you!
Dec 01, 2013 | Electrolux EW1000i Front Load Washer
How to operate frigidaire washing machine, ill dont have a manual since i bought it 2nd hand ...
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
I need instructions on how to replace front boot seal on my neptune front load washer
Jan 03, 2011 | Maytag Neptune MAH9700 Front Load Washer
Front load washer
Hitchhiker, you don't have to remove the front of the washer. The original boot was glued in areas around the door. They came out with a new design because of water leakage on the bottom. The new kit, part number 5303937187 comes with a spring that holds it on to the panel. You can do one or two things, if you don't have the leaking problem, glue the boot back on. Or you can order the new kit, it comes with instructions and replace the whole boot. Check it out, it might be covered under service flash #26-758BR. In any event this job can be done by leaning the washer back against the wall to make room between the tub and front panel. You are going to need an assist, it's better with 2 people. Catriver...post back.
Aug 10, 2006 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
