Question about 2001 Chrysler Town and Country - 3.3L V6 - Electric Cooling Fans
How do i stop the flywheel from turning when i'm trying to remove torque converter bolts
Trying to remove transmission, flywheel moves need to prevent it from moving so the bolts will loose. best tools to use
    Top Expert:
  • Flex A Lite Master
  • 49,128 Answers
Hold a flat blade screw driver in the ring gear teeth against the bell housing opening will do the job
Posted on May 02, 2015
    Scholar:
  • 131 Answers
Usually i put a ratchet on the crankshaft bolt and wedge it against the frame.
    Top Expert:
  • 50,169 Answers
Usually with a flywheel holder / turner
Posted on Apr 16, 2015
How do I remove my fly wheel?
This is not an easy job and requires a substantial amount of knowledge. you will also need a decent floor jack or a transmission jack. The transmission must be pulled or slid back to get the flywheel off the engine. The first thing is to take the transmission dust cover off or in some cases the starter. The starter needs to come out anyway. This will reveal the torque converter bolts. You can use a pry-bar to turn the flywheel around so you can get to each torque converter bolts. The other option is to turn the crank with a socket and breaker bar from the front of the engine/harmonic balancer. Then you must drop the transmission or if you can slide it back enough to reach the flywheel bolts mounted to the crank. Once you remove the center bolts in the flywheel it should drop out.
25882486-p1aus1s3fwe0ue1iewji4qiu-2-0.jpg I hope this helps!
Sep 27, 2015 | 2000 Oldsmobile Intrigue
I have a 1997 gmc suburban it has a v8 and it just start to make a sounds like a whining/grinding sound and it's comeing from the transmission and one person said it sounds like the flywheel and it only...
you could check it by removing torque converter pan.remove bolts from the flywheel and push back to transmission the torque converter. ..Try to move the flywheel with your hand if you feel end play then it is crack
hope it helps
Mar 22, 2014 | Cars & Trucks
Remove a flywheel
The clutch come out with the engine since it is bolted to the fly wheel. If you had an automatic transmission then you would need to remove the torque converter bolts from the flywheel so that the torque converter would stay in the transmission. If you pulled the manual transmission the clutch would stay attached to the flywheel. It's the same when pulling the engine.
Aug 07, 2012 | Saturn Vue Cars & Trucks
Trying to take out an automatic transmisson out of a 1998 chevy S-10 got all the bolts and electrial and hoses lose but transmission is still hung up need help
Did you take out the bolts that connect the torque converter to the flywheel? If not, this is what is most likely hanging you up. Unlike a manual transmission where the clutch spins freely, the torque converter is bolted to the flywheel. To access these bolts, look on the bottom side of the bellhousing where the transmission mates to the engine. Tou should find an access hole covered with a black plastic plug. The hole should be roughly 2-3" in size. Remove this cover and manually rotate the flywheel using the accessory drive pulle bolt or have someone bump the key until the bolts are visible. If my memory serves me, there should be 4 bolts. Remove these and the transmission should come free. Just make sure it is properly supported to prevent injury. Hope this helps out. Have a GREAT day!
Sep 03, 2011 | Chevrolet S 10 Cars & Trucks
How to remove a transmission for a 2002 GMC Yukon
Removal & Installation 4L60E/4L65E To Remove:
  1. Remove or disconnect the following:
    • Transmission fluid
    • Transmission oil level indicator tube and seal from the transmission
    • Plug the oil level indicator tube opening in the transmission.
    • Remove or disconnect the following:
    • Shift cable end from the transmission shift lever ball stud
    • If equipped with a transfer case, remove the front propeller shaft.
    • Rear propeller shaft.
  2. Plug the transmission oil cooler line connectors in the transmission case.
  3. Remove or disconnect the following:
    • Starter motor.
    • Transfer case, if equipped.
  4. Support the transmission with a transmission jack.
  5. Remove the transmission mount nuts.
  6. Remove the transmission crossmember.
  7. Remove or disconnect the following:
    • Torque converter access plug 4L60E/4L65E removal 9308kg37.gif
    • Flywheel to torque converter bolts
    • The two bolts securing the transmission rear mount to the transmission
    • The transmission vent hose, fuel lines, and the wiring harness from the transmission
    • The stud and the bolt securing the transmission to the engine
    • The six studs and one bolt securing the transmission to the engine. Install tool J21366 onto the transmission bell housing to retain the torque converter. Pull the transmission straight back.
    • The transmission from the vehicle
  8. Flush the transmission oil cooler and cooling lines when you remove the transmission.
To Install:
  1. Install or connect the following:
    • Tool J21366 onto the transmission bell housing to retain the torque converter.
    • Support the transmission with a transmission jack.
  2. Raise the transmission into place and remove the tool from the transmission.
  3. Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must be flush onto the flywheel and rotate freely by hand.
  4. Install or connect the following:
    • Six studs and one bolt securing the transmission to the engine. Tighten the studs and the bolt to 50 Nm (37 ft. lbs.).
    • Stud and bolt securing the transmission to the engine. Tighten the stud and the bolt to 50 Nm (37 ft. lbs.).
    • Flywheel to torque converter bolts. Tighten the stud and the bolt to 46 Nm (63 ft. lbs.).
    • Torque converter access plug.
    • Transmission vent hose, fuel lines, and the wiring harness to the transmission.
    • Two bolts securing the heat shield to the transmission. Tighten the bolt to 17 Nm (13 ft. lbs.).
    • Two bolts securing the transmission rear mount to the transmission. Tighten the bolts to 18 ft. lbs. (25 Nm).
    • Install the transmission crossmember. Tighten the nuts and bolts to 70 ft. lbs. (95 Nm).
  5. Remove the transmission jack from the transmission.
  6. Unplug the transmission oil cooler line connectors in the transmission case.
  7. Install or connect the following:
    • Starter
    • Transmission oil cooler lines to the transmission
    • If equipped with a transfer case, install the front propeller shaft.
    • The rear propeller shaft
    • The shift cable end to the transmission shift lever ball stud
  8. Unplug the oil level indicator tube opening in the transmission.
  9. Install the transmission oil level indicator tube and seal to the transmission.
  10. Tighten the oil pan bolts and fill the transmission with transmission fluid.
  11. Lower the vehicle.
4L80E/4L85E To Remove:
  2. Plug the oil level indicator tube opening in the transmission.
    • Shift cable from the transmission shift lever ball stud
    • If 4WD vehicle, remove the propeller shaft.
    • If RWD vehicle, remove the propeller shaft.
    • The transmission oil cooler lines from the transmission
  4. Plug the transmission oil cooler line connectors in the transmission case.
  5. Remove or disconnect the following:
    • Starter motor
  6. Support the transmission with a transmission jack.
    • The two bolts securing the heat shield to the transmission
    • One nut and one bolt securing the transmission brace to the engine bracket and transmission
    • The two bolts securing the torque converter cover to the engine
    • The four bolts securing the torque converter cover to the transmission
    • The six flywheel to torque converter bolts
    • The two bolts and nut securing the transmission rear mount to the transmission
    • The stud and the bolt on the right side securing the transmission to the engine
    • The remaining six studs and the one bolt securing the transmission to the engine
    4L80E/4L85E removal 9308kg36.gif
  8. Pull the transmission straight back. Remove the transmission from the vehicle.
  9. Flush the transmission oil cooler and cooling lines when you remove the transmission.
To Install:
  2. Support the transmission with a transmission jack.
  3. Raise the transmission into place and remove the tool from the transmission.
  4. Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must be flush onto the flywheel and rotate freely by hand.
  5. Install or connect the following:
    • The stud and bolt on the right side securing the transmission to the engine. Tighten the stud and the bolt to 50 Nm (37 ft. lbs.).
    • Six flywheel to torque converter bolts. Tighten the bolts to 60 Nm (44 ft. lbs.).
    • The two bolts securing the torque converter cover to the engine. Tighten the bolt to 50 Nm (37 ft. lbs.).
    • The four bolts securing the torque converter cover to the transmission. Tighten the stud and the bolt to 33 Nm (24 ft. lbs.).
    • The transmission vent hose, fuel lines, and the wiring harness to the transmission.
    • The two bolts securing the heat shield to the transmission. Tighten the bolt to 17 Nm (13 ft. lbs.).
    • The two bolts and nut securing the transmission rear mount to the transmission. Tighten the bolts and nut to 25 Nm (18 ft. lbs.).
    • The flywheel to torque converter bolts.
    • One nut and one bolt securing the transmission brace to the engine bracket and transmission. Tighten the bolts and nut to 50 Nm (37 ft. lbs.).
  6. Remove the transmission jack from the transmission.
    • Starter motor
  8. Unplug the transmission oil cooler line connectors in the transmission case.
  9. Connect the transmission oil cooler lines to the transmission.
  10. Install or connect the following:
    • The transfer case
  11. Unplug the oil level indicator tube opening in the transmission.
  12. Install the transmission oil level indicator tube and seal to the transmission.
  13. Tighten the oil pan bolts and fill the transmission with transmission fluid.
  14. Lower the vehicle.
Oct 12, 2010 | 2002 GMC Yukon XL
Need to pull a siezed engine from a 99 avenger (can't turn it over to undo torque converter bolts) Can it be pulled without pulling the transaxle? (is there enough clearance to pull the engine with torque...
There isn't enough room to pull the engine without removing the converter. You can try to separate the engine and the trans far enough to get to the bolts with a wrench. Or remove the engine and transmission together and unbolt the two out of the car.
Jun 18, 2010 | 1997 Dodge Avenger
Does a torque converter for a 1989 ford bronco trwo have antyhing to do with a fly wheel
the torque converter bolts to the drive plate that supports the ring gear
Mar 24, 2010 | 1989 Ford Bronco II
Need a flywheel put on a 98 chevy suburban how much
I would say about $200-400. It involves disconnecting the transmission and torque converter bolts to the flywheel (3 bolts) and moving the transmission back far enough to remove the flywheel.
Nov 02, 2009 | 1998 Chevrolet C1500
Flywheel on 1997 Chevy Suburban 1500 broken
Jun 13, 2009 | 2003 Chevrolet Suburban 1500
96 Chezy Blazer Manual Transmission Removal
Did you remove the transmission lines too? did you remove the linkage from the gear selector to the transmission? And last. Did you remove the plate near the bell housing? If you remove that plate you'll see the flywheel teeth that the starter engages to to spin the engine over.. And you'll see bolts holding the torque converter to the flywheel. You need to remove one bolt.... Turn the engine over by hand at the crankshaft with a ratchet until the next bolt is in a position to remove. Remove it and continue till all the bolts are off.... Then try to remove the transmission... You absolutely have to unbolt the torque converter or it won't pull out. The space to get those bolts out will be fairly tight.. A ratchet wrench would be the fastest. A regular ratchet might fit.. But if it doesn't a box end wrench will work.
Apr 22, 2009 | 1996 Chevrolet Blazer
2001 Chrysler Town and Country - 3.3L V6 - Electric Cooling Fans Logo
60 people viewed this question
Top Flex A Lite Vehicle Parts & Accessories Experts
ray gallant
ivan whisker
ivan whisker
Bill Boyd
Are you a Flex A Lite Vehicle Part and Accessory Expert? Answer questions, earn points and help others
