Question about Pyle Audio Players & Recorders
How can u hook up the rca Jacks to a pyle pld71mu radio. Which ones there's a subwoofer and a rear output. I need help which jacks.
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
Drummernick
  • 440 Answers
SOURCE: hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Posted on Feb 11, 2008
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
  • 27 Answers
SOURCE: Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Posted on Oct 30, 2008
WILL IT WORK ON A TV THATS NOT BLUETOOTH CAPABLE
Hi Mike,
The TV requires an audio output jack. Either an Optical, a stereo "RCA phono" type or a stereo 3.5mm "headphone" type jack with the appropriate cable to mate with the speaker's optical or RCA input jacks are needed.
Download the manual from the page linked below under "Manuals and Downloads" and read page 7 where the details of these connection can be seen.
Pyle PSBV600BT Home and Office SoundBars Home Theater Sound and Recording...
Jul 14, 2015 | Pyle PSBV600BT Sound Base Bluetooth...
I have a samsung hw-c700 receiver which only has rca jacks for subwoofer output, however my digital research subwoofer only has speaker wire inputs and outputs, how do I connect this set up?
Radio Shack will gladly sell you jacks that will enable you to fabricate your own connectors. It should take you a maximum of fifteen minutes to complete the hook up.
Jun 12, 2012 | Audio Players & Recorders
How to hook up car radio to an amp when radio does not have RCA Jacks
They make a type of Amplifier that uses high level input from the speaker outputs. Contact a company called Crutchfield.com for details and prices. You ca also have a radio shop install preamp output RCA jacks to the factory radio, do an Internet search for shops that do this type of retrofitting.
Apr 29, 2012 | Cars & Trucks
I have a keenwood indash dvd player i want to hook my amp to it but it dont have rca jacks so how do i do it
If your indash radio does not have RCA outputs, you can do two things. You can purchase a line level converter and hook it to one of the rear speakers. This will allow you to tap into the speaker wire, then convert the signal to RCA. Then you plug your RCA cables in there. The other (my recommendation) is to purchase an "add an amp" wiring harness. This harness will install between your radio and vehicle harnesses. It will have RCA output and remote wire. Then you run those back to your amp and there you go. You can find these at the scosche or PAC websites. You can also try www.crutchfield.com
Aug 29, 2011 | Kenwood Car Audio & Video
I have a 93 chevy and i want a subwoofer put in it.. is there a way to hook it to the stock radio and if their is where
you can buy a radio wiring harness at a discount store or an aut parts store, it comes with directions. Hope this helps Tim
Aug 25, 2010 | 1993 Chevrolet K1500
Where are the amps and how do i by pass them for the stereo
The amps are located inside the radio. Most in-dash receivers that provide for "pre-amp outputs" also called "low level outputs" do so by providing female RCA type jacks. These are often found at the end of a short (4 - 6 inch) cable and are usually color coded red & white or red & black (some receivers provide a yellow RCA jack for video in / out, too). To use these RCA audio jacks, you need to realize that one jack is for the left channel source and the other is for the right channel source for a stereo signal. You will have to connect a compatible plug and cable of enough length to extend to a remote amplifier's RCA input jacks. The vehicle's speakers would also need to be connected directly to the same amplifier's output terminals. Using the two audio (left and right) RCA jacks will only allow the radio to control balance of the left and right audio, no fader (front and rear) control is possible. To get fader control, you'd have to either have a radio with four RCA low level output jacks (front L & R *and* rear L & R), or use the radio's speaker (or high level output) wires and connect them to the amplifier's speaker (or high level) input terminals.
All unused receiver wires should be terminated in a wirenut or securely wrapped in electrical tape to prevent accidental contact with grounded metal or other wires behind the dash.
I hope this helps!
Nov 11, 2009 | Car Audio & Video
How do you hook up a subwoofer to Alpine CDE-7858
go into the menu of the radio make sure sub output turn on
Aug 28, 2009 | Alpine CDE-7858 CD Player
Is it possible to connect my Altec ACS48 speaker system to my TV?
If your TV has audio output jacks, then yes, you can connect your speaker system to the TV. Run a stereo RCA cable from those output jacks to the audio input jack on the Altec system, using whatever adapter required. You will probably need to convert from RCA jacks to a 1/8-inch stereo plug for the speaker input. Or you can pick up a cable from Radio Shack that has the RCA plugs on one end and the stereo plug on the other, and omit the adapter.
If the TV doesn't have audio output jacks, there isn't any easy way to hook up the Altec.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Mar 04, 2009 | Audio Players & Recorders
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Car amplifers,,,,kicker amp's RCA jacks!
    You could do a couple things if your head unit has all three outputs, then take them and hook them into the inputs. If you have just the front and the rear outputs, hook those to the inputs front and rear. Then hook the output of the 4 channel to the input of the mono block. I hope this helped
    -Andrew Hawkins
    Mar 28, 2008 | Audio Players & Recorders
    51 people viewed this question
    Top Pyle Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Gerhardus Stroebel
    Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
