Question about Funai Televison & Video
32" funai flat screen tv controls stopped working has picture no sound cant change channels
    Top Expert:
  • Funai Master
  • 74,459 Answers
Try a reset to this set, and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 17, 2015
SOURCE: Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
Posted on Dec 22, 2007
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Posted on Jan 20, 2009
  • 60 Answers
SOURCE: Turn on JVC 32
There is a way to reset television. I have a jvc 42inch that was just going to main logo screen and not beyond it. If i remember correctly you unplug the tv hold power button for 5 sec on tv then let go plug in and start. If that dont work unplug and then plug and hold power button on tv for 5 sec. It is 1 of those combinations. My tv worked after that. I googled my problem and a website listed that some tvs need to be reset.
Posted on Aug 16, 2009
pabloloco
  • 2335 Answers
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
Funai tv 32 inch LED
what are you using with hdmi? if you are using a laptop you must go to your speaker configuration and change it
Dec 02, 2013 | Panasonic Televison & Video
I have a 42 in magnavox 43mf439b/f7 tv. It is about 2 years old. i have no picture but i have sound. if i change channels the sound changes. I did a little research and i believe that i have...
You were smart to test the image for burned out backlights! :)
Typically, on a screen this size, the backlight inverter is the first place to look.
I found the part number...
27-D026774 Funai TV Module, backlight inverter, PNF10092, I420H1-16A0, 42MF439BF7
You can by it here...
http://www.tristatemodule.com/p-13231-27-d026774-funai-tv-module-backlight-inverter-pnf10092-i420h1-16a0-42mf439bf7.aspx
Aug 23, 2011 | Magnavox 42MF439BF7 42 in. TV
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Channel scanning
SEEMS LIKE CONTROL PANEL SWITCH, ONE OF THEM IS STUCK OR DEFECTIVE, CONTROL PANEL NEEDS TO BE TESTED
May 11, 2008 | Vizio L32 32 in. LCD HDTV
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Televison & Video Logo
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
