My washer keeps giving me an error code 3E.
My washer gets to the rinse cycle and begins to spin in slow speed. I then get a 3E error code. I have replaced the motor, but that didn't fix my problem. I have also tried clearing the diagnostic code memory. What advice can you give me on troubleshooting?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for blockage,s
Posted on Apr 17, 2015
LE LIGHT IS APPEAR
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 12, 2012 | Washing Machines
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
Alarm which we do not have before. normal cycle. also on a rinse cycle. ocasionally loud banging noise.
You didn't mention if the machine was giving any error codes. Do the following steps to get any stored error codes and post them back to me.
Select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
Jan 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Le keep coming on
dfgf
dSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG Washing Machines
What does LE mean?
Nov 28, 2010 | LG WM-2277HW Front Load Washer
My washing machine is cannot spin ,it show error code LE
Nov 28, 2010 | Washing Machines
I keep getting a code le why?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
My LG tromm washer keeps saying LE and no matter what I put in there it continues to say this
Check whether a large load size been used with a gentle wash setting?
Check whether the washer been overloaded
Thank You
Sep 04, 2010 | Washing Machines
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
