Question about Bernina BERNETTE 65 Mechanical Sewing Machine
It will make a few stitches and then lock up - Bernina BERNETTE 65 Mechanical Sewing Machine
  • Jimmie Sill Apr 16, 2015
    Hi susan brown, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?By lock up do you mean it just won't turn anymore even if you use the hand wheel?
Bernina 440 qe is not stitching properly. It stitches a few stitches and locks up and will not move forward. Why is this happening?
I don't know a whole lot about sewing machines and coudnt tell you much without seeing it, but I had that problem and discovered that my needle was bent.
May 05, 2017 | Bernina Sewing Machines
Machine does not appear to have a button to sew in reverse
try these suggestions
Reduce the stitch length to zero. The machine will stitch in place and form a locked stitch
1) rotate the material and sew over the same stitching. Leave the needle down in the work and raise the presser foot, then turn the fabric around.
2) decrease the stitch length to very small for a few stitches
OR
3) hold the fabric and prevent it from feeding at the beginning and end of a seam, which makes very short stitches
4) stitch about 1/2", raise the needle and presser foot, return the fabric to the beginning position and stitch over the first half inch of seam again. Do the same at the end
Jun 17, 2015 | Euro-Pro Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Baby lock quest
The top thread is looping right? This particular machine loves a well oiled hook system, and it needs to be vacuumed out regularly. Compressed air is not good on this machine, actually it is not good on any machine if the covers are on. So check for thread trapped inside the hook system by flooding with oil and oscillating the machine back and forth for a few minutes.
Two other possibles: something is snagging the top thread like thread trapped inside the hook system or a little burr on the stitch plate. Moving faster means the fabric tractors harder, so any burrs will be mre noticeable.
Dec 03, 2013 | Baby Lock Imagine
Sewing machine locks up after first few stitches
Refer to the manual. The machine may need cleaning and general maintenance or service.
Mar 10, 2010 | Sewing Machines
My Evolve serger is skipping stitches while using the 4 thread safety stitch which is a chain stitch with a two thread overlock. Sews fine for a few stitches and then skips a loop which unravels. I checked...
First, change the needles making sure to use the el705 needle system. Second, make sure the subsidiary looper is engaged properly (plugging up the upper looper hole). Also make sure the needles are all the way up in the machine. This should do it or it may need to be adjusted but the Evolve is a very, very reliable machine. Hope this helps...
Nov 20, 2009 | Baby Lock Evolve
Bernina BERNETTE 65 Mechanical Sewing Machine Logo
47 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
