Question about Steam Fast SF-450 Iron
I need a steamer head to replace broken one for a SF 450 steamer.
My name is Joshua Lewis
How to remove mineral build up fron steamfast sf-465
Alternatively, use in your steamfast
  1. Fill the steamer with an equal part solution of water and household vinegar and let this soak for an hour.
  2. Once the hour is up, shake steamer to adgitate
  3. Then, empty the steamer and add a couple cups of mixture through machine.
  4. If you don't have any vinegar to hand, try lemon juice!
Organic Cleaner White Vinegar For Calcium and Mineral Build Up
Removing Mineral Deposits from Household Surfaces
How to Remove Mineral Deposits
Apr 15, 2014 | Steam Fast SF-465 Iron
I have a steamfast steamer that is tripping the circuit breaker. Any ideas why?
you check the wiring inside which may have short circuit, then the connector for filament which get short.
Nov 28, 2012 | Steam Fast SF-661 Iron
I have mineral buildup in my steamfast steamer.model sf-510. How do i fix this problem?
there is a product called CLR that is made for cleaning mineral build up works great and is available almost anywhere
Jul 16, 2012 | Irons
The trigger on the handle is not working and neither is the steamer HELP
Need a little clarification, do you feel/hear click when pressing trigger? No means the trigger inner actuator tab is broken...easy fix, just gently pry off cush rubber cover on handle from front to rear (gently to not scar up the works) and lift. Steamer not working?...is it getting hot? Steam building up in the boiler? Need a little more information here before I can proceed...
May 31, 2010 | Rowenta DG-980 Iron
Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
May 19, 2010 | Rowenta Commercial Garment Steamer - White
Wanted please instructions and reciept for the use of my hinari steamer st 450
Take this link to Hamilton Beach and choose "irons" and enter your model number "14770" to download and print your free owners manual.
http://www.hamiltonbeach.com/use-and-care/use-and-care.php
Oct 17, 2009 | Hamilton Beach Steam Excel 14770 Iron
Parts
Call 800-711-6617 to get a new Hose Base for $3.00. I just ordered three of them and with shipping it was around $17.00. They didn't give me the part number.
Jul 05, 2008 | Steam Fast SF-450 Iron
Steam Fast SF-450 Iron Logo
Top Steam Fast Irons Experts
Are you a Steam Fast Iron Expert? Answer questions, earn points and help others
