Question about Samsung Refrigerators
Where is the reset button on the ice maker of Samsung model rf263aewp
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
On the icemaker itself. should be on bottom or right side. Small rectangular button. Press and hold for 5 secs to reset
Posted on May 05, 2015
SOURCE: Samsung Ice Maker on Mdl RB215LASH
ice maker fill line frozen up
Posted on Apr 07, 2008
  • 5 Answers
SOURCE: Ice maker not working.........
Reset button on the bottem front right of ice maker
Posted on Jul 30, 2008
aborcass
  • 2651 Answers
SOURCE: Ice maker only produces crushed ice
not really a reset button but htere is a solenoid that controls the type of ice coming out of dispenser. with the ice bucket in place give a look at it from underneath and find the brass rod spanning from front to back of bucket. that rod hooks into a solenoid catch that when activated lifts the rod up and down for crushed/ or cubed ice.. after locating the "hole" in which the rod enters you should also see a corresponding plastic ring that would catch the rod upn activating stich and pull/up and down.. Ill assume that the "catch ring" is tuck in the up positon , might only be frozen up in which case you can hit it with a hair dryer to melt it, its also possible that the \solenoid had melted it self in the up position in which case you need to replace it.. to check this theory you can hook the brass rod into the ring assy in which case youll only dispense cubed no crushed
Posted on Nov 03, 2008
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
Samsung 33 cf french door ref. Top ice maker not making ice. Bottom ice maker ok water and crusher in door works. Reset button causes clicking sounds.
some stripped gears more than likely..
ck this site with the model #... sticker is inside the freezer or frig walls or door trim.
https://www.repairclinic.com/
not a project that you can't handle they have a helpful 800# too.
Jan 28, 2018 | Samsung Refrigerators
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Where is the ice maker reset button on a Samsung side by side RS267LVSH?
On my Samsung refrigerator,the ice maker circuit module at the front on the ice tray (the clear plastic box with the circuit and relays inside) has a black tab at the bottom that you depress. It does not look like a button and requires that you press it firmly.
Nov 07, 2010 | Samsung RS2534 Side by Side Refrigerator
Jul 22, 2008 | Samsung RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Ice Maker
Most of the samsung's have a reset button on the bottom front of the ice maker that just pushes in and it should start the cycle.
Oct 22, 2007 | Samsung RM255LASH Side by Side...
Samsung RB215LABP Bottom Freezer Ice Maker..
refrigerator working great then the refrigerator portion went frmo 35deg to 61 freezer is at 4deg can not understand whats up and i cant get the damn thing to do ****
Oct 07, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Refrigerators Logo
89 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
