Question about Brinks 1-1/2 In. Brass Combination Resettable Padlock
My locked is jammed in the unlocked position and wont move to lock it how do i fix it
My friend unlocked the the lock and its jammed in the unlocked position and will not move to lock it
I can not manually with hand, remote, or key get the lock to move and lock the door on a 98 Lincoln Navigator.
is it only one lock if so it could be corroded inside and that would be why it wont move i had a similar problem on my nissan i tried to lubricate it but it didnt work so i had to replace the lock this is also why you should lubricate your locks with graphite every 3 months
Dec 03, 2014 | 1998 Lincoln Navigator
I hve a 2007 nissan altma and the front passenger door wont open. I replaced the locking assembly, and as soon as i closed the door it locked again. When I press the unlock button it moves but nothing...
sounds like the actuator in the door that locks and unlocks the door is jammed or too weak to move the lock assembly to fully lock/unlock positions. the linkage may be in a bind that can cause the same problem.
Jun 14, 2012 | 2007 Nissan Quest 3.5 Minivan
2002 Hyundai Elantra Drivers dorr Lock Jammed not unlocking properly. Lock lever on inside and key on outside are stuck and door move bery much and will not unlock car. Originally cable in door to release...
Same thing happened with mine. It turned out that the power door lock motor went out. Since the handle or the switch can unlock the driver's door, both of these mechanisms are connected. When the door lock motor goes out it freezes in whatever position, it was last engaged.
Nov 06, 2010 | Hyundai Motor 2002 Elantra
Door locks move a little but wont go all the way to the lock or unlocked position
Pop off interior door panels & lube up door lock actuators with a good penetrating oil, move lock buttons back & forth manually & try to use switch to move back from unlock then to lock & back in forth. If they will not free up you will need door lock actuator.
Jul 11, 2010 | 2000 Ford F350 Super Duty Super Cab
My key wont turn, so i cant move my car how can i fix this? we have moved the steering wheel shitloads to unlock it. i think my friend may have put a different key in and its now jammed?
without taking the steering column apart, I would first try to get the key out of the steering wheel by turning steering wheel back and forth, don't worry about putting some effort into it. keep the steering wheel moving and turn the key back and forth at the same time. It might take some time but its the only way to get the key out of lock position.
Aug 28, 2009 | 1992 Plymouth Voyager
I have a 2004 chevy venture. The power locks do
open the door and look on the side of door for little switch up and down ,it a safety switch ,little gray lever sticking out on the side of doors, move it up or down ,read decal on the door jam,hope to help robert b.
Jul 16, 2009 | 2003 Chevrolet Venture Passanger
Lock wont open!
You have to remove the door panel and manually move the lock release rods inside of the door it could prove to be vary difficult. A body shop is the next step if this proves worthless.
Jan 28, 2009 | 2001 Oldsmobile Silhouette
Door lock accent 2000 rear door lock jammed
door handle on the out side has never worked. And my wife moved the child saftey lock to the locked position and closed the door, now we can't open it. How can I move the child saftey lock back to the unlocked position when the door won't open?
Jul 02, 2008 | 2000 Hyundai Accent
Brinks 1-1/2 In. Brass Combination Resettable Padlock Logo
640 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
