Question about Brinks 1-1/2 In. Brass Combination Resettable Padlock
How do I reset it?
Its open and its jammed and it wont close
Self cleaning
There is a SAFETY INTERLOCK, if you opened it then locked... Is that what you said? It can not clean if the door is not locked.
If you unplug the stove and this will give it a reset. but you may have done some mechanical damage that you will have to inspect to see what it is doing. Is the Locking handle working properly? Is anything jammed ? Ect... Look at the Mechanical components first...
Mar 01, 2014 | Frigidaire Ovens
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
I was printing when 2nd sheet got part stuck i pull it out from the top because it was only stuck a bit now the error light is on and wont reset its self. why?
Hi, did you try opening and closing the printer's doors and covers? Many printers won't recognize that the jam has been removed until it sees the doors open and close.
Jan 19, 2011 | Office Equipment & Supplies
E studio 150 Paper jam light wont reset. Can't find any jam.
Most often break the sensor on leaving the paper, check the sensor of the leaving the paper, afterwards include the device and open and close front lid.
Sep 15, 2009 | Office Equipment & Supplies
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Hp officejet 6210 all-in-one
open that door, clear the jam , mostly paper trapped
close door and acknowledge with pressing button next to okay.
Should disappeasr.
If not still jammed.
If not, reset the printer.
Apr 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Jan 24, 2009 | Ricoh Aficio 150 Copier
Brinks 1-1/2 In. Brass Combination Resettable Padlock Logo
600 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
