Question about Garden
Power washed it while it was running.next time tryed to start it I here the relays click but no power to starter cellanoid.fuses check ok. Im semi handy but this one got me.
  • 1,923 Answers
Battery could be low power since wetting all the wires could cause it to short out till it dried. Charge the battery up before you go farther. If that's the problem a lot cheaper. Also make sure the battery cables are clean and tight.
Posted on May 03, 2015
Where is fusiable link in a 2001 jeep grand cherokee
4.0L or 4.7L engine> the park switches are different.
you pulled a starter with out removing battery neg lug?
is that it?
your post makes it hard to see what the story is.
you replaced starter because car would not CRANK
or
you replaced starter, and shorted out the big cable and boom
and now all things are dead. what?
ill assume car would not crank one day
and you gue$$ a bunch of parts and guessed wrong,
guessing is very expensive.
------------------------------Testing wins--------------------------------------
so no crank 101, posted 100 times. ILL ASSUME it's a A/T tranny.
(im ignoring new parts, i never assume anything works i test it)
  1. check all fuses in all boxes. using a voltmeter. 12vdc both sides key on and battery cables lugs area all clean and tight x4 ends.
  2. you check battery volts its 12.6vdc rested, good.
  3. you crank, and the solenoid just clicks. or only the starter relay only clicks, (more later on that)
  4. you see that battery voltage never drops below 11v and crank time. (11v is typ, tad less if in Alaska, or bad battery or not charged fully)
  5. You then jumper cable crank car, off a running donor car ,just like Mr. AAA tow does.... same to a fault. (google how) (hinting your battery is good, I have a battery load tester so can check)
  6. if this cranks ok, the battery is bad. (happens or is discharged)
  7. car still will not jumper crank.
  8. we next hot wire the starter small wire to big lug. keys in pocket. Called hot wiring a starter solenoid.
  9. engine does not crank, starter bad. or may be battery cables.
  10. engine does crank nice , my keys are in pocket ,see?
  11. ok starter is good, at test 10. so we now know its ok. easy huh>
  12. now we know the key line is bad. 1 wire. end to end. easy.
  13. you try to start in neutral, omg it starts. bad PRNDL switch.
  14. or its bad starter relay.
now we show how it cranks. good starter and battery (& cables)
keyon,
put shifter in to park then neutral and crank.? fails both?
the starter relay must close cranked, if not, bad park switch or bad relay
in this moment (cranking) there must be 12vdc across the 2 relay coil pins.
pin 85 and 86 with volt meter, if 0v, the PRNDL switch is bad.
or on 4.7L the TRS switch.
if the relay closes, then jb fuse f31 is ok and pdc f8 must be good.
and you then turn key to crank. and relay pin 87 goes to 11v to 12v.
this then is a single wire that goes directly to the starter solenoid
tiny wire , it goes to 12v and starter cranks, 11v what you see here
unless in alaska , less. (10v ?)
see red arrow what is voltage there cranking?
we can go fast , if you just do that.
25513501-qtmfudt4eg5vdkejwfy5ompz-5-0.jpg the transmission switch grounds the lower coil,here.
if not the starter will be dead forever.
both fuses must be good, or same.
12vdc arrives at top left fuse, and is hot only cranking.
if the right fuse, glows above the relay can not send power to the starter solenoid.
Mar 04, 2015 | 2001 Jeep Grand Cherokee
What can I check next after replacing starter the car still wont turn over. not a sound.
The starter wire runs from the ignition switch to the neutral safety switch (located on the transmission), then to the fuse and relay, then to the starter solenoid. Pull the crank/starter fuse look at it, put it back in if it is good. This gets rid of corrosion problems. Try to start. If it doesn't I would go to the safety switch next.
Nov 15, 2014 | 2003 Dodge Stratus
Where is the fusable link for the starter located on a 1996 buick lesabre
it should be right up next to the battery its a inline link fuse
Jun 06, 2014 | 1996 Buick LeSabre
Van will not crank over, seems to have no power to the starter
Battery? If OK, turn the ignition switch to START and listen for a click indicating the starter relay is closing. If it clicks, the starter may have failed. If no click, check 10A CRANK fuse 8 in the instrument panel fuse block. If OK, check 40A IGN-A fuse in the underhood fuse/relay center. If OK, check for 12V at the top of the IGN-A fuse. If OK, the ignition switch, the park/neutral position switch (shift quadrant), or the starter itself are the only other possibilities
Sep 28, 2012 | 2002 Chevrolet Express
Not starting which relay controls fuel pump
1994 ford Bronco was starting and running fine. My daughter drove it 3 miles to school that morning then a few hours later she went to start it and it would'nt start. The door chime and all the dome lights, lights on dash lite up as normal and when you turned the key to (start) position you could hear the fuel pump then it just would click and not turn over and start. Jumped the battery that didn't work. Had it towed home and tried a few more times that night to get it to start but no luck. Next afternoon went to check it out again and for the heck of it thought id try starting it. Would'nt ya know it..It STARTED right up? After checking Battery and solenoid..etc I thought it was the starter but now im not sure.
Mar 02, 2011 | 1994 Ford Bronco
1990 sedan deville won't start. battery is good.getting power to everything but nothing to the starter.
Hello! There are several components that can cause no power to the starter...Lets eliminate...#1...Do you hear a "click" when you turn the key? It is the Starter Enable Relay...Powered by fuse #17 (15A)...The relay is enabled by the Pass Key Decoder Module...
Anti-Theft device...If no click is heard; The fuse is blown, the relay is bad, or the key you are using has a bad chip...#2...If you hear a "click"...The Park/Neutral switch is open/defective...#3...The power cable connection to the starter has a poor connection...
Guru..............Saailer
Oct 04, 2010 | 1990 Cadillac Deville
My 98 jeep grand cherokee wont start. It doesnt even click or turn over. battery is fine, headlights, dome lights, all go on. Radio doesnt work with ignition on. I checked ALL the fuses, I replaced the...
fuse 8 40a supplies power to starter relay and ignition switch, to close the starter solenoid and engage the starter which draws directly from the battery. check to see that the starter relay is closing, if not ensure that the park neutral switch is not faulty (open circuit), it provides path to close relay (ground side) on the 85 - 86 terminals. if the starter relay does not close the starter will not run. if you have a spare relay swap out the relay for a quick fix attempt. hope this helps
Jan 28, 2010 | 1998 Jeep Cherokee
Car only turns over once in a while. When it does
Your suspisions may be correct but more likely the starter relay
Jul 29, 2009 | 1990 Nissan 300ZX
I have an 85' Honda Shadow and the cellanoid went out on it, and when I replaced it, it stoped working. I tested out the cellanoid and it works, and the starter switch is opening and closeing, but the...
well, if the battery is good, there are 3 things- the starter relay, which one end is connected to the start button, the other way to the solenoid, then the starter. from your brief desciption, sounds like the starter relay, is a small cube, that year it may even be aluminum
Jun 17, 2009 | 1986 Honda VT 500 C Shadow
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
