Question about Pioneer AVIC-N1 Car DVD Player
How to replace screen cable - Pioneer AVIC-N1 Car DVD Player
Replace ribbon cable going lcd compaq presario screen
Please replace it with a brand new flex cable. Please post the "4 tiles miniature screen".
Feb 12, 2014 | Computers & Internet
Why is my replaced lcd screen not lighting up?
1) Wrong LCD screen
2) Video Cable (LCD Cable) is not connected tightly.
Motherboard side, or LCD screen side; or both.
3) IF, a screen Inverter is used, the small cable from the Video Cable, that connects to the screen Inverter; is not connected, or has a loose connection to it. (screen Inverter)
4) An LCD screen, and a screen Inverter are a Matched unit.
If it's the wrong LCD screen......................?
5) IF, a screen Inverter is used; the diagnosis was wrong, and the LCD screen was replaced.
90 PERCENT of the time, the fault is a bad screen Inverter.
A) Laptop's LCD screen uses a CCFL, (Or more than one), for a Backlight; the laptop uses a screen Inverter.
Diagnostic flowchart leads from Graphics Chipset, to Video Cable, to screen Inverter, THEN, LCD screen.
Expensive LCD screen was replaced, instead of the actual part that needed replacing;
Video Cable: $9 to $22
Screen Inverter: $9 to $22
LCD screen: $60 to $245
B) Laptop's LCD screen uses LED backlighting, and does NOT use a screen Inverter:
Diagnostic flowchart is;
A) Video Cable;
A Video Cable should have it's connections PHYSICALLY checked.
You have to try to push the connectors in tighter.
Visual inspection alone will NOT do.
Making sure the Video Cable connections are tight, and this does not fix the problem, then the Video Cable needs to be removed; and every wire in the Video Cable checked for Continuity with a multimeter set to OHM's. (1K)
Not feasible, then take the Video Cable down to the nearest small computer shop; and have the resident tech check it for Continuity.
Should only be a few bucks.
Or just replace the Video Cable.
(Parts changing I know, but...........?)
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or more than one), or a series of LED's.
(Light Emitting Diode)
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to Fluorescent lighting used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little large than 1/16th of an Inch.
Average thickness is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A screen Inverter is used to convert the power, (Electricity), from the laptop; for the LCD screen, and Backlight.
As previously stated, Backlighting that uses CCFL, uses a screen Inverter.
LED backlighting MAY, or MAY NOT use a screen Inverter.
When the LED backlight technology first came out, it seems some did use a screen Inverter.
It also seems as the technology advanced, LED backlighting does Not use a screen Inverter.
Regards,
joecoolvette
May 14, 2013 | Sony Computers & Internet
FIX A CRACKED IPHONE
Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new
screen cracked you need to replace screen with another one by a sucker on the screen if will not suck do to the crack glue it on and slowly pull up the screen and remove the screen cables and the hidden cable for the screen (lift the black clip up carefully and pull out the screen in direction of the cable to come out. replace screen and put cables back on and clip cable back down.
Mar 15, 2013 | Apple iPhone4 4G iPhone 4
Horizontal blinking lines appear on the screen of Sony Vaio VPCEL 10EL
Possible cause:
1. Video card failure.
2. Bad connection between video cable and LCD screen.
3. Bad LCD screen.
4. Faulty video cable.
Possible troubleshooting steps and repair solution:
1. First of all, test the laptop video output on the external monitor. If you see same flashing lines running through the image on the external monitor, you have a problem with the video card. If flashing lines appear only on the laptop screen, the failure is not related to the video card.
2. Just in case, try re-seating the video cable connectors on the motherboard/video card and maybe the back of the LCD screen. It' s not likely but possible that connection is loose and reconnecting the cable will fix the flashing lines.
3. If re-seating the cable connectors doesn't help, most likely you have a faulty LCD screen. The LCD screen has to be replaced.
4. If replacing the screen doesn't help, try replacing the video cable. It's very unlikely that this problem is related to the video cable but there is a slight possibility of that.
Oct 26, 2012 | Computers & Internet
Why is my ipod 4g screen blank
is it an ipod nano ?
Remove the two screws on the panel on top of the Nano and remove the top panel.
Use a case opener tool to pop the plastic screen cover off the unit.
Slide the screen up to expose the orange ribbon cable on the bottom of the screen that connects to the motherboard.
Unplug the orange ribbon cable from its port and slide the screen out of the Nano.
Fit a new screen in the Nano and plug the ribbon cable into the port.
Replace the screen cover and top panel of the Nano.
hope this helps
http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&qpvt=how+to+replace+an+ipod+4g+screen&FORM=VDRE
Sep 29, 2012 | Audio Players & Recorders
Aspire 5516 internal screen cable
If it was working before, then before replacing the video cable I suggest you reseat the video cable/connector to the motherboard.
Yes you can replace the ribbon cable.
You maybe be able to get one from this WEB site.
LCD screens and Inverterswww.lcdparts.net
Mar 24, 2012 | Acer Aspire 5516-5063 Notebook
Need a replacement screen, its cracked any chance on getting a replacement, is it worth replacing?
Hey how are you!!!
What is your unit? If your unit is a laptop ou need to follow this.
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no back light.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the back light inside the old screen lights up, apparently the new screen has defective back light lamp and has to be replaced.
Good luck
ICmanServer
Aug 14, 2009 | Memorex MM7000
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Dead screen
To replace that cable you have to disassemble the entire phone including the keyboard, screens and the lower part, then buy a new flex cable (this includes the keyboard, keyboard backlight, backlight driver, cover sensor, screen cable and connectors. all of this is part of one flex cable) and replace it.
You have a 70% chance of breaking the new cable even before getting the phone reassembled.
Apr 30, 2008 | Motorola Mobility RAZR V3
Razor v3 phone
rmorales89 - you need to have the flex cable replace.
skyblue10 - either replaced the fex cable or replace the LCD/screen.
fivelone - yes you will have to pay for it to be fixed..so replace the flex cable
Nov 16, 2007 | Motorola Mobility RAZR V3
Pioneer AVIC-N1 Car DVD Player Logo
59 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
