Question about Solo 425dx Backpack Sprayer
Is there supposed to be small round hole in plastic on bottom of backback
Now that I have replaced all O-rings and firing valve assembly. Why do the nail heads still hang up with contact on the side of driver rod?
It sounds like your complaint is that the driver isn't returning all the way up and is getting hung up on the next nail?
There is an o-ring on the cylinder near the bottom that covers several small holes around the cylinder (LB1015) - this acts as the check valve and provides the air reserve to push the piston back up - if this o-ring is damaged or missing it will prevent the piston from returning all the way to the top.
26266403-4ukbeyx4iefg4em1tlva0y55-2-0.gif The other thing to check is make sure your driver is not bent or the end chipped / worn.
Best of luck - let me know if this has helped.
Aug 25, 2016 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Installing Harley Davidson Chrome & Rubber Hand Grips Large 56263-96A
Sounds like the throttle lock is possibly binding up. Remove the right grip. There should be a little half moon shaped piece of plastic in there at the bottom of the switch housing. This plastic piece will have a small hole in the outside edge. This hole has to be placed over the pointed end of the throttle stop. The throttle stop is the plastic star wheel on the outside of the bottom of the right switch housing. There is a small metal Jesus clip on the inside of the switch housing. This clip is supposed to hold the stop from being turned completely out of the switch housing. It's possible the clip came off and is wedged in there.
May 20, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
Anybody know how the horn wiring behind airbags is supposed to go? 1998 Chevy cavalier 2.2L. I'm replacing the airbags cover and don't know where the wire and ground goes...(
It is really very simple. The horn lead with the plastic connector and the spring pushes in and turns to lock in the large round hole at the upper left center of the steering wheel. If you look into the hole, you will see the contact down in there with a plastic "tube" with a slot in it for the horn connector to go into.
The ground clip (wire with brass or steel clip on it) simply pushes into the hole in the steering wheel center near the bottom (It grounds to the steering wheel center).
Feb 21, 2012 | 1998 Chevrolet Cavalier
I have three Lyra stools. They stand on plastic feet, to prevent them to make holes in the parket, but they scratch terribly. What can I do about that=
Go to a home center store like Home Depot. They sell self-adhesive material that you can put on the bottom of the stool feet to replace the plastic feet. They will not scratch the floor. There is also a product they sell called Sliders, that is plastic, but is supposed to NOT scratch the floor, but I like the material ones. They come in different shapes--round, square, and larger pieces that you can custom cut to fit the bottom of your stool legs. Take the old plastic ones out before attaching the new stuff.
Oct 06, 2011 | Audio Players & Recorders
I have a super shooter hamilton beach cookie press. the long plastic screw will not stay in place, the small plastic gear falls out.
Hi Jane,
The bolt isn't supposed to stay in one place. It's meant to turn, so the dough can be pushed to the end of the plastic tube. When you're putting the parts together, wind the bolt to one end of the long (7 inch) screw. Next, put the 1.5 inch circular disk on the same end of the column as the bolt. Then, stick the screw in the little hole; the bolt will just lay inside the hole. The screw will go almost all the way inside the handle. Then, attach the plastic tube, making sure to line up the indentations in the tube and on the circular disk. Then, add the cookie dough. When you press the handle (turning on the Super Shooter), the screw should turn, causing the round disk to move up and push the dough toward the tip/disk. I hope this helps. Happy Baking!
Chris
Dec 05, 2010 | Hamilton Beach Microwave Ovens
Error code 13 on my 5oo plus series washer, it will not coplete the load or unlock the door, im afraid the clothes are going to start smelling
On the small round disk at the bottom right...insert a small round pointed object into the hole and push gently, while do this rotate the disk clockwise. This will allow you to remove the disk. Look inside and there will be a slender plastic rod next to the drain clean out. Pull down gently to manually unlock the washer door. Unfortunately that will unlock the door but probably not fix what caused the issue in the first place.
Jan 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Primer button bowl brass bolt and plastic.
what is plastic ? all there should be is a bowl , then small round gasket , then brass nut . if it doesnt go on you must have disturbed the bowl gasket ( black round )
Sep 19, 2008 | Garden
Solo 425dx Backpack Sprayer Logo
274 people viewed this question
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Steve
Steve
Level 1 Expert
Are you a Solo Garden Expert? Answer questions, earn points and help others
