Question about Bosch Dishwashers
Doorlatch accidentally locked on open door of Bosch dishwasher model shp65t55uc/02
    Top Expert:
  • Bosch Master
  • 10,875 Answers
Unlock it
Posted on Apr 26, 2015
markevans
  • 148 Answers
SOURCE: Kenmore dishwasher locks. after cycle, can't open door
bad solenoid or controller
Posted on Dec 21, 2007
SOURCE: Bosch #SHU9955 Integra dishwasher for
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Posted on Oct 12, 2008
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
SOURCE: Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Posted on Oct 07, 2009
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Model SHP65T55UC. Why is it beeping?
Hi. I will try to help you.
If what you saying is right, after you hit start. And after some time the dw should indicate a error. I need that error code to be able to help you.
Kind regards
Geir
Technical service enginer @ Bosch Siemens appliances
Feb 15, 2016 | Bosch Dishwashers
Model SHP65T55UC/02. How can I replace the door handle?
You will need to remove the whole front door of the unit and replace whatever parts you find are broken.
I just found your machine on "Sears Parts Direct" and found all your parts and their availability and their cost.
You can buy your parts from them, or on Amazon, or on e-bay.
God bless your efforts.
Jan 16, 2016 | Bosch Dishwashers
How do i operate a basic bosch dishwasher
On many Bosch dishwshers (especially those with the controls on top), they expect your to press the appropriate cycle and option(s) buttons, and then press the Start key, ALL WITH THE DOOR OPEN. Immediately after pressing the START button, close the door (within 3 seconds), and the dishwasher should start.
On other Bosch dishwashers, if you open the door, the poser button is automatically turned off. On those models, you must close the door, turn the Power button ON, and THEN press the appropriate cycle & options buttons. If your dishwasher has a START button, then press it; otherwise just wait 10 second with the door closed.
See? There is no such thing as a "basic bosch dishwasher". Next time, if you have a question, please provide the model number of your dishwasher (or other appliance).
Mar 20, 2015 | Bosch Dishwashers
Do you have a user's manual
The manual is found here:
Bosch Order Management System LINK:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
You can also find these downloadable pdfs at this link (for your same model):
IU - Instructions for Use
SI - Short Instructions
In - Installation Instructions
PT - Programme Table
RP - Recipes
SP - Supplement
Jul 16, 2014 | Bosch 500 Series SHP65T55UC Fully...
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Mar 30, 2014 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosh wishwasherhow do you unlock the child safety lock?
Hello there and welcome to fixya The child lock function of your Bosch dishwasher prevents accidental program changes and stops children playing with the controls while the appliance is running. You might want to turn the lock off if it has been accidentally turned on. The controls of the dishwasher are disabled, preventing you from starting a new wash, while the child lock is running. The lock is simple to turn on and off, as necessary, in just a few seconds
Read more: How to Get the Child Lock off a Bosch Dishwasher ' eHow.com http://www.ehow.com/how_12069321_child-lock-off-bosch-dishwasher.html#ixzz2E7bFXnhs
please feel free to give me a rating if this works for you it helps me give you the best help i possiabley can ok
Best regards Mike
Dec 04, 2012 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
117 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
