Question about Home
Why are my pennies being counted as dimes? - Home
    Top Expert:
  • 46,177 Answers
HAHAHAHA surely you joke we do not know fix for piggy banks
Posted on Apr 16, 2015
How many combinations of 56 cents are there?
Great question.
You could start with the number of quarters, which can be 0, 1, or 2.
If there are 0 quarters, then you only have dimes, nickels, and pennies to worry about. You can have 0 to 5 dimes. There can be 0 to 11 nickels. For pennies, there can be 1, 6, 11, 16, 21, 26, 31, 36, 41, 46, 51 and 56.
Time to work out lots of combinations!
Sounds like a summative project for a data management or statistics course or a great computer programming assignment;)
Good luck,
Paul
Find all combinations of coins when given some dollar value
Jan 16, 2016 | Office Equipment & Supplies
FS-4DA coin sorter won't count pennies
The good news is that the unit is functioning, it's just counting pennies. I had the same problem with quarters and is a fairly easy fix. I won't get into any disassembly details, but you'll need to gain access to the infrared detectors (mounted to the motor assembly) and possibly the emitters (mounted to the front panel LCD display/push button board). Also, please be careful not the damage the wire harnesses when removing the top cover. Once apart, you can use your cell phone camera (which is sensitive to infrared) to see a purplish/white glow from a healthy emitter. Compare the penny emitter to the others and chances are it will have a lower output level and need replacing. If the penny emitter is strong, then check the detector with any infrared remote control( TV, cable box...) by pointing the IR remote control towards the penny detector and pushing any of its control buttons. This should make the penny amount count up, and fast too, as the remote sends out IR pulses while a button is being pushed. If this test doesn't increment the penny count, then the penny detector needs replacing. But before you do, try this remote control test on another known good detector to verify your findings. Please keep in mind that other malfunctions besides an emitter and detector could be the cause of your problem, but given the FS-4DA circuitry, the odds are extremely high that you have a bad emitter 1st, then a detector 2nd, as emitters are known to degrade over time and especially when continuously powered, as in the case of a switched 'ON' FS-4DA. FYI...IR emitters and detectors can be purchased from Radio Shack. Good luck and take care not to electrocute yourself when powering the unit with its cover removed.
Feb 21, 2014 | Royal Sovereign Fs 4DA Model Fs 4DA Coin...
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
Volume
Not enough information. You need the mass density for the alloys the coins are made of. Besides, you cannot use physical measures without specifying the units. Furthermore when you say that " the weight of the nickels and dimes is equal to 743?" does it mean the total weight of all those coins, or the weight of the nickels and that of the dimes are both equal to 743 (weight units).
Sorry you will have to be more forthcoming with the necessary information.
May 22, 2013 | Mathsoft Computers & Internet
Grandson put a penny into the SD slot while the TV was on. It immediately stopped working.
This happened to me yesterday. My daughter put a penny and a dime in the SD slot and none of the buttons or volume were working on my TV.Only the power button would work.
I fixed it by simply removing the penny and dime out of the SD slot and then i held the power button for 10 seconds. After I unplugged the TV from its power source for 5 minutes and then plug it back in. When I turned the TV back on everything was back to normal.
For a second I thought I was going to have to buy a new TV, lol. Hope this helps. If it doesn't work the first time then try it a second time.
By the way I have a Panasonic PT-52LCX66 LCD Projection TV..
May 02, 2011 | Panasonic TC-P46G25 Flat Screen Plasma...
The needle seems too light on the record because it continually skips in the "backward" direction. I don't know how to adjust the controls. Thank you.
These are pretty cheap units as far as quality and workmanship go.
The ancient fix is to tape a dime to the arm just above the stylus (needle).
If a dime doesn't work, use a penny.
Apr 09, 2011 | ION Audio Vinyl Recording Turntable
SEAT WON'T GO FORWARD OR BACKWARDS
check for penny or dime in track
Jul 21, 2009 | 2006 Chevrolet Impala
1994 landcrusier lighter fuse
Check All SOCKETS FOR PENNIES DIMES HAIR PINS this Is Common
Jun 20, 2009 | 1994 Toyota Land Cruiser
Programming sharp XE-A404
there is no programming to round your sales up to a nickel or dime
Dec 24, 2008 | Sharp XE-A404 PC Desktop
Home Logo
705 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
