Question about John Deere Garden
F525. Updated mower switch by John Deere is not engaging mower
    Sergeant:
  • John Deere Expert
  • 187 Answers
The John Deere F525, a front cutting machine, has 3 fuses.
20 Amp
15 Amp
10 Amp
Check the 15 amp fuse. I believe this supports the PTO clutch. If you replace the fuse and it blows again, check the electric clutch. You will likely find burnt or melted wires. The bearings do go out on these clutches causing them to run hot and eventually burn up.
PTO Clutch will not engage: There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
Resistance 3.7 ohms
Current Draw 3.25 amps
It does not give the air gap.
It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
Cap Screw torque 55 lb-ft (75 N.m).
If the fuse blows, I recommend you check the resistance of the clutch. If the clutch is shorting to ground it will show zero resistance when you ohms the connector wire to a ground position. In which case, you will have to replace the clutch.
Fixing Electric Clutches
Other possibilities.
On the F525 there is a cut-off switch in the hydraulic system. It is a low pressure cut off. If you were running the mower and deck and then it suddenly stopped, it may be low pressure in the hydraulics. It will not automatically reset as you are using the same volume for the drive pumps. Once the oil gets low enough it cuts out the deck drive 1st, then the drive pumps.
Posted on Apr 17, 2015
  • Eugene Rounds Apr 17, 2015
    Current Warner and Ogura replacement PTO clutches are drawing 5-7 amps with resistance around 1.75 ohms.
  • Kprime
    Kprime Apr 17, 2015
    Good to know. Makes sense, a heavier clutch, more cutting load.
  • John Deere Master
  • 1,169 Answers
I take it that you had the rocker switch. Did you wiring in the new connector as instructed? If so check for voltage at the PTO connector with the switch in the engage position if voltage is present then you have a bad PTO clutch assembly.
Posted on Apr 16, 2015
    Top Expert:
  • John Deere Master
  • 51,482 Answers
If John Deere place did it take it back to them till it works properly
New battery on F525 John Deere mower won't stay charged-battery connections are good-is voltage regulator bad?
Either the alternator is not charging properly or the diodes in it are defective and discharging the battery when the ignition is off.
Sep 06, 2017 | John Deere Garden
I have a jd f525 engine runs until i engage the mower deck
sounds like you may have a bad or unplugged safety switch. check all of them unplug and plug back in.
Apr 21, 2016 | John Deere Garden
Replace fuel pump P/N am109212 on John Deere Model F525 Lawn Mower
Ok what is the problem? fuel pump not working? try checking for dc volts at pump.
Dec 30, 2014 | John Deere Garden
John Deere 160 Mower Deck Switch - mower deck does not engage when switch is turned on. The "dead man" engine shutoff still functions when the switch is engaged - if the switch is on and there is...
Hi, check that you have 12 volts to the pto when the switch is on. It sounds like your pto is fried as the switch is functioning correctly. Regards Phil.
Sep 20, 2011 | John Deere Garden
Need belt diagram John Deere F525. Help please
Here are many of the John Deere belt diagrams...
http://www.google.com/search?q=john+deere+belt+diagram&hl=en&client=firefox-a&hs=cYZ&rls=org.mozilla:en-US:official&prmd=ivns&tbm=isch&tbo=u&source=univ&sa=X&ei=HjDHTb_TJsfv0gG-wr37Bw&ved=0CCAQsAQ&biw=1440&bih=684
heatman101
May 09, 2011 | Garden
John deere f525 mower, wont start, battery good, ignitor good, coil good, no positive power to ignition switch, electric on off switch for cutter looks tampered with, and a safety switch below frunt of...
The front mount mower has a safety switch on the park brake linkage and the seat belt linkage as well as on under the seat which is for the PTO,The one under the seat on the linkage just behind the battery is a culprit that needs adjusting to get the PTO to engage but it sounds like you need to deal with the seat switch circuit or replace the seat switch.
Jul 08, 2010 | John Deere Garden
John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Oct 02, 2009 | John Deere Garden
Garden Logo
859 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
