Question about John Deere Garden
Bought new switch to engage mower, but still doesn't engag
    Sergeant:
  • 462 Answers
Out of adjustment?
Posted on Apr 23, 2015
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
White z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
Apr 11, 2012 | Oregon Scientific Electric PTO Clutch for...
Belt. came off... pulling up blade engagement knob nothing seems to happen.....I have trackter up on blocks with blade cutting height at 1 with engine runnig the blade engagement knob switch ...
sounds like a bad PTO, that is the electrical gizmo on the bottom of the engine's driveshaft which engages the bottom pulley, running the deck. you might luck out and find the fuse is blown so follow the wire from the PTO back until you find the fat part in the wire. the fat part is an in line fuse holder with a fuse in it. if the fuse is bad and blows again, you need a new PTO
Aug 19, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
New mower, purchased May 2011. The self-propel drive has stopped working. I have looked at it but cannot see anything loose or ????
Look on top of your mower as well as underneath your mower. Check the belt for excessive wear. Check to see if anything came loose. Move up to the area that engages the drive assembly. Is the cable if so equipped loose or disconnected , is there a spring missing, or is the cable jammed so that it doesn't engage the drive unit. Check up to the handle, possibly the cable broke, or has disconnected in some way. Just because something is new this doesn't mean it can't break, or get thrown out of kilter. You will find your problem. GOOD LUCK.
Jul 13, 2011 | Toro Garden
I HAVE A CUB CADET 50 INCH CUT ZERO TURN, WHEN YOU PULL THE PTO SWITCH TO ENGAGE THE BLADES THE BATTERY WILL DISCHARGE.
Most likely a short. You have to look in the area where engage switch gets blades going. You will find a cut wire or wires that are touching metal. This will kill a battery very quick. Fix wire , tie up wire so this doesn't happen again, and off you go. GOOD LUCK.
Jun 16, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Engine cuts out immediately when blades are engaged - new mower
Check the seat switch. If it is loose/out of adjustment, the mower will die when the blade is engaged. The logic of the mower requires the operator to be present (on the seat) for the blades to engage, or for the mower to move. All of the safety switches are dependent on the seat switch. Dirty connections at the switch, or the switch being out of position is the likely culprit.
Best regards, --W/D--
Jun 04, 2011 | Husqvarna Garden
When engaging the moer it doesnt want to start
The tractor has a safety feature that doesn't allow you to start the engine with the mower engaged. Just disengage the mower, then start the engine. Once you have it running, then engage the mower.
May 21, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have a white outdoors riding mower....the mower shut off when i engage the pto...is the switch bad?.....can i by-pass it?....how do i test the switch????
Check the safety pressure switch under your seat. When you engage the PTO and get off the lawn mower, it will kill the engine. I had the same problem; drove me nuts. I thought it was the switch that is compressed when the PTO is engages. It wasn't. It was the safety under the seat. Bypassed and it worked fine. Ordered a new switch from a local repair shop. Good luck.
May 26, 2010 | Garden
1998 John Deere 325 belly mower 48" deck will not stay engaged.
There is a safety switch on the diferential that lets the tractor know that your not backing up that is likely defective,unplug it until you can get one in to replace it and you should be good to go.It's on th right side mid housing on the hyrostatic unit[rear diff].
Apr 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
41 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
