Question about Sport & Outdoor - Others
My Tennis Tutor Carousel won't spin..Why - Sport & Outdoor - Others
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: tennis tutor
Google the model number or call the maker or their customer service number if it is found.
Posted on Jun 13, 2012
Door won't open, carousel won't spin, buttons light up but nothing happens. If the carousel is out of alignment, how can I fix it?
U have separate motors for the door opening and closing as well as the carousel spinning. Chances of both motors going fubar at same time is nil. .What do they both have in common? Yep, power supply!!!
Feb 03, 2016 | Audio Players & Recorders
Replacing battery on tennis tutor
it is very simple . Just lie the machine down as u play tennis . Use a hex key and loosen out 6 hex screw joining the two half of the upper and lower black boxes of the tennis machine . take out some screws on the upper control panel not all of them.and one more hex screw on the upper box . Lift off the upper box. You can the battery right there. Proceed to change the battery. U can buy a battery for $23 on ebay but the unit need 2. If u need any other parts , call tennis tutor manufacturer phone is attached to the machine. They are very nice and send out replacement parts free of charge by Federal Express.
Jun 04, 2014 | Sport & Outdoor - Others
Balls stuck in tubep
Hello
It sounds like there is a build up of material on either the ball throwing wheels (decreasing the overall velocity and causing the balls to stick in the tube) or a build up in the actual tube.
From the manual, it recommends against using new tennis balls in the unit as this directly contributes to the debris build up on the ball throwing wheels. It is recommended to use slightly used balls as some of the waxy coating and ink on the ball would have been partially worn off.
I would suggest using a spray cleaner (like Windex) to clean out the tube. IF you get any material on your cleaning cloth, continue cleaning and, if necessary, use a mild abrasive pad to help with the cleaning process.
As for the ball throwing wheels, the manual suggests using a 40 to 60 grade sand paper and cleaning all of the wheels until they are slightly rough to the touch.
The manual for your unit can be found here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=3&cad=rja&ved=0CEAQFjAC&url=http%3A%2F%2Fwww.nedtennis.org%2Ffiles%2Ftennis-tutor-prolite-user-manual.pdf&ei=9fJ9Upu2I9GIkQf144DAAg&usg=AFQjCNFSv4Co1N7iJRhQODi7rKYGDUzwbA
I hope this helps you out!
Nov 09, 2013 | Tennis Tutor Plus Player Tennis Ball...
What does an umpire do in paddle tennis?
According to the USPTA (The United States Paddle Tennis Association) an umpire is responsible for:
a) Introduces players, keeps and calls out score at each point, game, set, and match.
b) Checks net height.
c) Repeats "out" or "fault" calls of linesmen.
d) Sees that players change sides, receive, and/or serve as specified in Rules
e) Sees that play is continuous within the Rules.
f) Suspends play when weather or other conditions make this advisable. (Subject to confirmation by Referee).
g) Supervises spin for choice of serve or court.
h) Calls the players to "action". (17,27,28,35,37)
Jan 14, 2013 | Sport & Outdoor - Others
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 | Toys
I'm in my 50's, can I start playing table tennis?
Definitely! You should know that Table tennis is asport for all ages, and it is never too late to get started. You should know that in the year 2008, Olympic table tennis canbe called the Veteran Year as 38 year old Gao Jun and34 year old **** Chendirectly qualified for the 2008 Beijing Olympic Games on the women's side. Andon the men's side, 45 year old David Zhuangwon the right to attend the Olympic Games as the USA' sole male representative.
Jul 09, 2012 | Sport & Outdoor - Others
Tennis tutor
Jun 13, 2012 | Dryers
2550L carousel won' t rotate when I push the button. Need to get the cartridges out to put in a newer one that I bought.
This is usually caused by generic toner cartridges. The only way to turn the carousel is to take the top cover off and then manipulate the solenoide on the top right hand side of the printer. This allows the carousel to turn to where you want it.
Jun 09, 2011 | HP LaserJet 2550L Printer
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
Cd wheel spining non stop
ITS NOT THE WHEEL SPINNING ITS THE LASER ITS TRYING TO READ THE DISC THAT CAUSE IT TO SPIN FAST AND SLOW FAST AND SLOW YOUR LASER NEEDS A CLEAN
Jun 27, 2008 | Wurlitzer Jukebox 1015 One More Time...
Sport & Outdoor - Others Logo
23 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
