Question about GE Refrigerators
I have 17 years old GE refrigator copper fitting I want remove water line from back
    Top Expert:
  • GE Master
  • 44,351 Answers
Well make sure water is off and take it off. wrap end in plastic bag and forget it .
Posted on Apr 16, 2015
How to install water tank on GE side x side. I have the new tank to install. Need diagram of connections.
Hello.
I do not believe any diagrams exist on the web for such diagrams. Basically the way it goes is as such
The tank has a long line and a shorter line
the shorter line connects to the water valve on the back of the refrig.
the longer line runs underneith and connects to the connector behind the freezer door lower hinge cover or that area by the lower freezer door hinge. depending on age of refrig. that fitting the tubes connect to unscrew or on newer models the collar on the inner part of the connecter is push in while pulling out tube to remove old tube
Aug 17, 2011 | GE Refrigerators
Tip
GE / Hotpoint S xS Refrig: Will not dispense water
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
on May 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Condensor fan running all day
when you say you removed the cardboard, did you remove the back panel that covers the compressor, fan, and coils from the back? If so that is what is causing it to run too much, this will also effect the cooling.
May 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Ge profile side by side is not dispensing water, have removed the line at door and there is not water coming out. What do I do next.
At the bottom of the freezer door ( remove the kick plate , 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the door line is frozen , GE has a dispensor heater , pt # WR49X10173 , to help eliminate the freezing of the line .
Dec 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
We purchased foreclosure house that has a GE fridge tpx21prx-possibly 13 years old-no info but does it need filter for ice and water use? There is no filter inside fridge-does copper line need replacing...
This model does not have a filter for the ice and water, you can add an inline filter in back of fridge water line, they sell them at any hardware store, you dont need to change copper line unless it is corroded.
Sep 19, 2009 | Refrigerators
Think I have pinhole leak in 1/2'' copper water pipe
What type of pipe are you looking at?If it is copper then you can fine someone to solder it.If it is plastic pipe with glue joints,then you get some glue call rain and shine,clean first then apply wait a few minutes.But turn the water first.
Mar 14, 2009 | Plumbing
Replaced GE SmartWater filter in my GE refrig and water wil l not flow thru it,why?
We replaced the water line to the refriderature. It was plugged by a coroded copper sleve.
Apr 23, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridg
water line in freezer door is froze up. Call GE customer service to see if your ref. has a service bulletin.
Jan 05, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
