Question about Garden
Grasshopper 620t clicks but will not start - Garden
  • Eugene Rounds Apr 17, 2015
    Hi Carolyn Arnold, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Tractor and Deck Serial Numbers are required for me to download the service info for this mower or you can download them from the Grasshopper site with same info.
    http://www.grasshoppermower.com/support_...
I have a model 2132 grasshopper mower. The right hydro motor stopped working. How do I disassemble this hydro motor to repair it ?
Grasshopper doesn't seem to sell repair parts for ZT mower hydromotors. The motor is only available as a unit for $1000.
That being said, someone built it out of machined parts, so it could be rebuilt if you can get the machine work done. Maybe.
Here is the site -
Drive Assembly Model 2132 1987 Grasshopper Lawn Mower Parts Diagrams The...
Oct 08, 2017 | Garden
Console board for 620T
What is it we are looking for 620T doesn 't give me anything
Feb 01, 2015 | Cars & Trucks
Grasshopper repair manual
go to grasshopper.com
Aug 31, 2014 | Garden
Can you drop the feed dogs with an Elna Grasshopper?
No the grasshopper has fixed feed dogs. There was a feed dog cover plate when the machine came out. This part is no longer available
Apr 06, 2014 | Elna 2007 Mechanical Sewing Machine
Battery losing charge
Sounds like you have defective diode rectifier. this little box when working properly allows your voltage to only go 1 way to charge the battery. if you have used a vehicle to boost the tractor you have damaged the rectifier. because a vehicle running puts out 14.8 volts lawn equipment is 12 volts only you can boost using a vehicle only if it is NOT running
Apr 04, 2014 | Garden
Grasshopper 225 owners manual
You are in Sewing Machines, not Lawn Tractors Mowers. Apologies
Jan 27, 2014 | Sewing Machines
How to remove mower deck of grasshopper 720
Contact the manufacturer/distributor directly to obtain the information.
Nov 25, 2011 | Garden
I want to print out a manual on how to operate, maintain this dish washer. "Aristone model -LS 620T "
THe best option you have is this document. Hope it helps. Plese accept the solution if helpful otherwise post a comment.
Sep 05, 2011 | Dishwashers
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Just need a wire diagram for a woods 1250
I owned the same model, quite simple wiring. I went to the local Grasshopper Dealer and cross referenced it with the Grasshopper model 1212. (which is the same model because grasshopper made all of Wood's mowers for quite some time) I asked them politely and they printed it off for me for free and then I made a few purchases (oil filter, air filter, etc) because I didn't want to seem like a cheap skate.
Aug 27, 2009 | Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
