What is the definition of a polygon - Office Equipment & Supplies
    Top Expert:
  • 10,875 Answers
Here ya go,although fixya is not a personal dictionary for you,
In geometry, a polygon /?p?l???n/ is traditionally a plane figure that is bounded by a finite chain of straight line segments closing in a loop to form a closed chain or circuit. These segments are called its edges or sides, and the points where two edges meet are the polygon's vertices (singular: vertex) or corners. The interior of the polygon is sometimes called its body. An n-gon is a polygon with n sides. A polygon is a 2-dimensional example of the more general polytope in any number of dimensions.
The word "polygon" derives from the Greek ????? (pol?s) "much", "many" and ????? (g?n?a) "corner", "angle", or ???? (g?nu) "knee".[1]
The basic geometrical notion has been adapted in various ways to suit particular purposes. Mathematicians are often concerned only with the bounding closed polygonal chain and with simple polygons which do not self-intersect, and they often define a polygon accordingly. A polygonal boundary may be allowed to intersect itself, creating star polygons. Geometrically two edges meeting at a corner are required to form an angle that is not straight (180°); otherwise, the line segments may be considered parts of a single edge; however mathematically, such corners may sometimes be allowed
Posted on Apr 16, 2015
  • Office Equip... Master
  • 3,368 Answers
A plane figure with at least three straight sides and angles, and typically five or more.
ERROR CODE L6
Polygon motor lock detection
Detail : The polygon motor does not rotate.
The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock
signal is detected for 1sec during rotation of the
polygon motor.
Cause : Polygon motor unit abnormality
Improper connection or disconnection of the
polygon motor and the harness.
MCU PWB abnormality
Check and remedy : Use SIM 61-1 to check the polygon motor
operations.
Check connection of the polygon motor
harness/connector.
Replace the polygon motor..
Replace the MCU PWB.
Apr 30, 2014 | Sharp AR-M160 Laser Printer
I cant find out what plolygon looks like
Hi. Go to wikipedia.com. It explains in detail about polygons. A simple definition is: Aplane figure with at least three straight sides and angles, annd typically five or more.
Mar 19, 2013 | Mathsoft Computers & Internet
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
How do convex polygons differ from non-convex polygons?
A convex polygon is one with each of its interior angles less than 180 degrees and every line segment between any of its two vertices remains inside or on the boundary of the polygon.
150px-pentagon.svg.pngExample of a convex polygon (WIKIPEDIA)
A concave polygon will always possess an interior angle with a measure that is greater than 180 degrees.
150px-simple_polygon.svg.pngExample of a concave polygon (WIKIPEDIA)
Aug 11, 2011 | Computers & Internet
Does circle has a side
A circle has four different ideas to sides.
-Inside and Outside (two)
-No sides (zero)
-Disk idea, top and bottom (two)
The meaning of the word SIDE depends on its context. A polygon in the plane has, by definition, n vertices and each pair of consecutive vertices are joined by a side. It is clear that a polygon with n vertices has n sides. In general, the word side depends on the dimension of the figure -- a side is always part of the boundary. So what is the side of a circle? If you think of the circle as a disk then it it has an up-side and a down-side. If you think of it as a curve, then it has an inside and an outside. If you think of it as the limit of an n-sided regular polygon, then one can justify the answer that the circle has infinitely many infinitesimal sides. :
the question, "How many sides does a circle have?", is too ambiguous to have a definite answer.
Jun 07, 2011 | Computers & Internet
I have a toshiba photocopiar and this copiar problem disply of error L 6 10 code pl resolved/ solution problem
The polygon motor does not rotate. The motor lock signal is detected for 6sec after
rotation of the polygon motor. The motor lock signal is detected for 1sec during rotation of the
polygon motor.
Cause:
Improper connection or disconnection of the polygon motor and the harness.
MCU PWB abnormality
Check and remedy:
operations.
harness/connector.
Jun 02, 2011 | Toshiba e-Studio 161 Copier Copier
Sc335 ricoh 2045 copier
  • Code: 335
  • Description:Polygonal Mirror Motor Error 1: ON Timeout
    The XSCRDY signal is not issued (LOW: Active) within 25 s after the polygonal mirror motor switches on.
  • Causes:• I/F harness of the polygonal mirror motor disconnected or defective. • Polygonal mirror motor or polygonal mirror motor driver defective. • Polygonal mirror motor drive pulse is not output incorrectly. • GABIC cannot monitor XSCRDY signal.
Apr 12, 2011 | Office Equipment & Supplies
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
263 people viewed this question
jasbo
jasbo
