Question about Cub Cadet Garden
Got a new cub cadet cc 720 es when I engage the drive belts it makes a squeak/rattle noise from the front deck, took off the top and can not seems to pinpoint the source of the noise.
    New Friend:
    Problem Solver:
  • 7 Answers
A lot of hydrostatic rotary mowers squeal when u engage the PTO (blades) even when properly maintained or even factory new ev like the toro groundsmaster which is top of the line in its style of mowers. At the shop at work we think it's due to a change in the angle of stress from the floating deck. Nothing to worry about. Just make sure that you completely drop the deck before you engage the blade drive.
Posted on Apr 18, 2015
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
  • 10 Answers
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
Posted on Oct 18, 2009
  • 146 Answers
SOURCE: cub cadet pto won,t stay engaged
Sounds more like a PTO clutch failure, rather than the switch. The clutch is mounted on the engine shaft, between the hydrostatic drive pulley (nearest the chassis) and the mower deck belt pulley (farther from the chassis).
Since it's an expensive part, make sure the problem isn't in the switch or wiring first. You could do that by probing the wires to the PTO clutch with an automotive test light - they are inexpensive and handy. Clip the ground wire of the test light to the chassis, and probe the hot wire to the clutch (it's the one that doesn't connect to ground) when the engine is running and the PTO switch is engaged. Obviously a helper has to be in the seat, and you should be careful doing this. If the light glows brightly, and the clutch doesn't engage, you definitely have a bad clutch. Good luck! Please rate my answer if helpful, thanks.
Posted on Jul 07, 2010
  • 10865 Answers
SOURCE: i have a cub cadet lt 1050 need diagram for drive
Hi. All of these questions are answered in the owner manual. TO download one go to this link http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
J.
Posted on Aug 03, 2010
Cub cadet ltx1042kw the blades will not engage
Either the pto is not engaging or you missed routed the deck belt. Google your model number and you should get a link where you can see the correct belt routing.
Jul 27, 2016 | Cub Cadet Garden
Cub Cadet LTX 1050 50 inch. How do I get the deck belt over the PTO?
A common problem:
Make sure that:
1) You have the right belt if it's a replacement.
2) The mower control is in the "DO NOT CUT" or "NOT ENGAGED" position.
3) The tension idler has fully retracted.
Jul 18, 2015 | Cub Cadet Garden
Looking for the sensor schematics for a cub cadet series 1000, LT1050 hydrostatic lawn tractor. anyone help me?
Try looking at the directional lever at the Transmission. The PTO for the deck will shut off when shifting into reverse. You may have to simply disconnect or jumper the reverse switch depending on if it is normally closed or normally open. Try it both ways to see what works. Also check the engine oil level, The low oil level switch will shut the engine down if more than a quart low.
Feb 27, 2018 | Cub Cadet Lawn Mower Deck Drive Belt...
Was mowing-blades just quit turning-pto will not engage
Belt has broken, or jumped off the pulley, or jumped off the belt tensioner. Look at your deck and go from there. You may have to remove your deck to get to the belts under there cvers but you will see your problem.
Jul 03, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Belt keep coming off cub cadet 1042, all parts on deck have been replaced with new parts & still the belt comes off every time
my cub cadet used to throw the cutter belt too....till i took the drastic step of adding a bit more tension to the belt. this was achieved by drilling another hole on either side of the chassis about 1 3/4 inches to the rearward of the machine and moving the lift arms to the new holes. Viola, more belt tension, and furthermore there is now no interference between the tensioner and the rearmost run of the belt.
Oct 22, 2009 | Garden
Electric clutch on my 4 yr old Cub Cadet 2518 was intermittent
check fuse or power it up seperatly with 12volts (battery directly into the two terminals) to see if it is a wiring fault but it sounds like you need a new clutch assembly $$$
Jun 20, 2009 | Oregon Scientific Electric PTO Clutch for...
Noisey Cub Cadet mower
If the noise is coming from the deck, locate the idle pulley on the deck. there should be 1 or 2 rubber "bumpers" at the opposite end of the pulley arm where it meets the "j" pin. If they are missing, it will make a loud metal to metal sound.
Apr 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do you replace the mower belt on a cub cadet?
check the alignment of the ideler pully to make sure it is even withe the drive pulleys. if not in line it will cause the belt to break. There is a spacer that is on the idler that should be on top and not on the bottom of the pully.
Apr 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
125 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
