Question about Garden
Hard to pull starter rope with spark plug in - Garden
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
You have to overcome the 100-135 psi of compression by pulling the rope. Some manufacturers now incorporate a 'compression release' to allow a rapid spin of the engine with a moderate pull. It automatically resets when it fires so you may have to push the compression release more than once to get them started.
Yours does not have that option which is why they suggest sitting the saw on the ground and inserting your toe into the handle while holding the front of the saw down with one hand. That allows you to ge a bit agressive with the pull rope with the other.
Posted on Apr 21, 2015
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
dontbother10
  • 2220 Answers
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Posted on Sep 17, 2009
Testimonial: "cheers"
dontbother10
  • 2220 Answers
SOURCE: rope wont pull smooth enough to start engine feels like notch a t
I think someone failed to put oil in the fuel.
Determine if the warranty is active first. Most warranties are effective for 1 to 5 years. If yes return it to where it was purchased or find an authorized repair facility. A written diagnosis by a good independent saw shop ($10-20) might be a good idea at this point. It is difficult to argue repair charges with an authorized repair facility without some documentation in your favor.
1. Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required? If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated without oil mixed with the fuel?
· Remove the spark plug wire and plug.
· Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and inspect the cylinder, above the exhaust port, through the spark plug hole. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by the independent saw shop should be considered.
4. The final likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Posted on Oct 10, 2009
  • 4088 Answers
SOURCE: Poulan Wildthing pull starter problem hard pull;
Many modern saws have sufficient compression to present difficult pulling of the starter cord. Suggest trading in for a saw with a compression release. The only repairable problem with the present saw is if it is flooding the engine and you are trying to compress liquid fuel. You can tell by removing the spark plug and pulling the starter through forcefully--it will blow out raw fuel if it is flooded. Change the diaphragm in the lower carburetor chamber if it is flooded. Hope some of this helps!
Posted on Jul 03, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Can't pull the starter cord,
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
Posted on May 15, 2011
Testimonial: "TRIED SOULTION BUT THAT DIDN'T HELP."
String trimmer Won't start. Hard to pull starter cord with spark plug installed.
Remove spark plug turn trimmer so that spark hole is down and pull starter rope until all old fuel is evacuated from cylinder, place spark plug back in and try. If this is not problem and especially if it is still hard to pull you may have a ring that has broken and partially hung in cyl.
Aug 07, 2017 | Garden
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My stihl 041 saw very old made in germany farmboss but very low hours on it. will pop and smoke a little but not start. When I pull on the starter and it almost starts it gets very hard to pull on rope -...
Answer to 2 year old question about hard starting saw.There is a seal that goes bad and leaks chain oil into the crankcase.This will make it very hard or impossible to pull the starter rope. To start the saw,pull the spark plug, stand the saw on it's end so the bar is pointed up and pull the rope 10-15 times. Replace the spark plug and start.It will smoke for a while.To stop this from happening, always store the saw with the bar pointed straight down.
Jun 29, 2010 | Garden
Chain saw won't start - pull starter pulley hard to pull?
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
May 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter rope will not pull. Will pull smoothly
Lou
Sep 17, 2009 | Bosch Garden
Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
May 19, 2009 | Troy-Bilt Pony Garden Tiller
Oct 03, 2008 | Garden
Garden Logo
192 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
