Question about Car Audio & Video
Red light will not go off on my daul amp 800 watt hcompacitorhow to fix blown channel
  • 3,368 Answers
That sounds like an interesting piece of equipment. If the fuse is not blown it probably is an output transistor. Take it to a service shop.
Posted on Apr 16, 2015
  • 119 Answers
SOURCE: Speaker outputs blown on 4 channel amp
the outputs should be replaced in pairs, there are 2 to 4 pairs, but you sould only need 1 pair replaced. these transistors typically range between 10 to 30 cdn each + labour, look for 1 to 1.5h to replace & test the unit after repair. check your local repair shop for their rates. good luck
Posted on Nov 30, 2006
Cerfer39
  • 709 Answers
SOURCE: 600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Posted on Oct 23, 2007
SOURCE: brutus 1600 watt hi fonics amp
i have had the same problem with one of my amps that was given to me by a friend and one of the channels were blown. Blowing a channel can cause the protect light to stay on.
Posted on May 08, 2008
  • 109 Answers
SOURCE: my 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Posted on Jun 19, 2008
  • 56 Answers
SOURCE: can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Posted on Feb 22, 2009
I have a 800 watt ma audio i was loosening speaker clamps when one my kids turned tunes on and i touched amp with wrench causing a spark immediately shut car down but got a burnt smell. Protect light...
Afraid you may have blown an amplifier. If you have a AC voltmeter, audio generator and schematic, you can feed audio signal into unit and track the signal on both channels during amplification stages.and locate the spot where the amplification stops or one channel deviates from the other. And there is your culprit.
Sep 05, 2017 | MA Audio Car Audio & Video
Red light will not go off on my daul amp 800 watt I have it hooked up to a 1600 watt compacitor
The compactor probably crushed it! No clue as to what you are asking
Apr 16, 2015 | Car Audio & Video
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
I have two 1200 watt sony amps bridged red light on in one why?
If you are certain speaker isnt blown and you have correct phase wiring and so forth you have whats called a solder jump which is internal repair by dealer only! buy a new amp at dealer wholesale price here cheaper than having it repaired unless under warranty go here for wholesale pricing on almost everything audio wise:
www.godspeedaudioheaven.com
Jan 03, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
My 800 watt kenwood
Jun 03, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Car Audio & Video Logo
112 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
