Question about Car Audio & Video
Red light will not go off on my daul amp 800 watt I have it hooked up to a 1600 watt compacitor
  • 3,368 Answers
The compactor probably crushed it! No clue as to what you are asking
Posted on Apr 16, 2015
SOURCE: brutus 1600 watt hi fonics amp
i have had the same problem with one of my amps that was given to me by a friend and one of the channels were blown. Blowing a channel can cause the protect light to stay on.
Posted on May 08, 2008
  • 109 Answers
SOURCE: my 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Posted on Jun 19, 2008
  • 631 Answers
SOURCE: red protector light
Try this first:
Amp in Protect - Troubleshooting
If nothing there helps, you need to return it to the seller if it's under warranty.
Let me know if you have any other questions.
Posted on Nov 16, 2008
SOURCE: car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Posted on Nov 18, 2008
  • 56 Answers
SOURCE: can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Posted on Feb 22, 2009
Red light will not go off on my daul amp 800 watt hcompacitorhow to fix blown channel
That sounds like an interesting piece of equipment. If the fuse is not blown it probably is an output transistor. Take it to a service shop.
Apr 16, 2015 | Car Audio & Video
I have a 2500 watt legacy ice amp and im tryin to hook it up to two 900 watt rms soundstreams daul voice coils whats the best way
If you amp is 1 ohm stable you can run + to +, - to - on each voice coil. Wire them into the box. Run +'s to +'s on amp, - to - on amp
Other wise. If it is a 2 ohm stable amp, you run two 4 ohm dual voice coils to the amp + -, + -
If the subwoofers are 2 ohm, run + - on only one voice coil to the box for each and run + -, +- for 2 ohm load on amp or + - bridged for 1 ohm load.
I hope that makes sense.
Dec 03, 2009 | Legacy Audio ICE LA798 Car Audio Amplifier
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Need to hook up to a 4000 watt amp
Why would you hook up 4000 watt amp to a speaker that has only 1000 watts. Try a 800 watt amp instead unless you just dont want the spealers.
Apr 13, 2009 | Theater Research TR-9500 Car Subwoofer Box...
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Car amp blows 12 volt wire fuse
Jul 26, 2008 | Car Audio & Video
Amp getting really hot
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Apr 11, 2008 | Power Acoustik PS2-1600 Car Audio...
Car Audio & Video Logo
125 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
