Machine will not drain
Started load came back lid unlocked opened it and it was still full of water. Turned it to drain and spin pushed start and it started making funny noises. now it will not turn on after holding start button for a few seconds sensor light will turn on but then starts flashing
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Probley somthing in pump ie coins
Posted on Apr 16, 2015
Whirlpool W10240509A did not spin out all water. when i try to restart iti
mine just started doing this on the wash cycle then we have to turn it to drain and spin. Last night it filled with water and refused to do anything else so it said it was done, open the lid and still full of soap and water. Turn it to drain and press the start button and it does nothing, no lights come on. We bought it in 2012, before the washer we had was purchased in 2000, and we are still using the dryer from 2000.
Feb 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I still have wet close after spin cycle Why?
check the drain hose for any kinks in it,is it a top load or a front load washer and how old is it?the pump could be blocked with something or the tranny is bad.if it's a top load,set the timer on spin cycle,open the lid,start the spin and with a screw driver push down on the lid switch and see how the machine is spinning,if it's not spinning fast the tranny is bad.if the drain hose is stuck into a drain pipe pull it out and drain the water to see if the water is draining out good or partially draining,something could be in the pump or to much detergent,the washer can't pump out suds as fast as water then the suds turn back into water form again and the clothes are wet.
Apr 02, 2011 | Kenmore Washing Machines
The washer fills up with water and doesn't do anything else. the water is still in the washer.
check the lid switch,set the timer on spin,open the lid and stick a screw driver into the slot where the lid strike normally would close down into,push up and down it should make a clicking sound and the washer should start to spin and drain out the water,if it doesn't click ,spin and drain the lid switch is bad.
Apr 01, 2011 | Whirlpool LSB6200KQ Top Load Washer
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2010 | Kenmore Washing Machines
My washing machine wont drain the water out before spin cycle it stops and turns off after wash so when you open the lid its still full of water
Hi just read your posting.Now you said in your posting it does not drain before the spin cycle, but does it drain before the rinse cycle?Does your machine stop and beep and show an error code in your LCD display or if you have the other model a series of lights?Have you tried advancing the cycle to spin and pushing the start button?Please reply with additional information and I can help you track down this fault.
Jun 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
