Question about Boss Car Audio & Video
How to hook up a pair of boss 1000 att 10 inch woofers
    New Friend:
  • 25 Answers
Throw those subs in the garbage and be mad at yourself because you owned them.
Posted on Apr 28, 2015
2 Suggested Answers
  • 10 Answers
SOURCE: How do I hook up my 10 inch visonik sub woofers?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Posted on Apr 14, 2010
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
How do I wire a pair of type r 15 inch woofers to 2 pdx 1.1000 amps for maximum bass output
are u trying to run one speaker of each amp if so the should be dual voice coil jump one positive to the opposite side negative then take the positive thats not hooked up from one side and the negative thats not hooked up from the other side and run them to the amp but turn ur amp down all the way and work it up because one speaker will not handle all the power from one amp
Mar 30, 2012 | Alpine Car Audio & Video
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
Power in no sound out
ALWAYS CHECK UR FUSES FIRST AND FOR MOST
Feb 10, 2010 | Boss AUDIO SYSTEMS CX250 Car Audio...
How big/small can the Enclosure be on RIP210DVC Car Subwoofer
Specifications Key Features Type: Component Elements: 1-Way Function Subwoofer Size: 10" Powered: Non-Powered Nominal Power Handling: 500 Watt Technical Features Peak Power Handling: 1000 Watt Frequency Respond: 35 Hz - 2,200 Hz Sensitivity: 94 dB Impedance: 4 ohm Components Woofer Material: Paper Mounting: Enclosure: Non-Enclosed Top Mounting Depth: 5.5 in.
Apr 22, 2009 | Boss RIP210DVC Car Subwoofer
How to hook up 2 10 inch speakers
For best results the output resistance of the amplifier must equal the combined resistance of the speakers. So if the amps says 8 ohms and you have two 4 ohm speakers you put them is series or if the amps says 4ohms and you have two 8 ohm speakers put them in series. If it says 4ohm and you have two 4 ohm speakers best to use only one. It Depends on the output resistance of the amps. It is usually written at the terminals where the speakers are connected.
Sep 08, 2008 | Boss IQ 3KD.1 Car Audio Amplifier
Car Audio & Video Logo
173 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
