Question about Philips CCC132AT 13 in. TV/VCR Combo
Help! I have a Philips CCC132AT 13 in. TV/VCR Combo and recently it started to turn off by itself. When you turn it on it turns off by itself again within seconds. I have a tape in there and it won't eject. When you turn on the t.v. it says T EJECT and when you try to play the tape it says NO CASSETTE. Please help, any info would be nice. Thanks.
Re: Help!
Posted on May 10, 2008
  • 934 Answers
Re: Help!
My guess is that the prisim broken or led (light emitting diode) below it has failed so the vcr is stuck in an endless load...
It will have to be taken apart and the tape in it manually unloaded by turning the load motor counter clockwise. Then visually inspect the prisim and test the diode.
If any of this sounds too foreign take it to a good shop and they'll have it back and running in no time..
Hope this helps!
Posted on Nov 14, 2007
0 characters
3 Points
Sylvania 9''--turns on, turns off by itself after 3-4
check the motor charge belt on the vcr and change it
Jan 06, 2010 | Sylvania SRC22134 13 in. TV/VCR Combo
Tape stuck in tv/vcr combo
just open it up and get a screw driver and push it out
Jun 22, 2009 | Sylvania SRC22134 13 in. TV/VCR Combo
Turns off!!
more than likely the VCR load mechanism has a problem it may be out of sync or the load sensor LED inside the mechanism has failed (most common problem). a tech should repair this.
Jul 16, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
Sharp Model 27SC370
Same problem here. TV would turn off but would not turn on after a period of time (until waiting a minute or two) then able to start again. Intermittent problem too.
Jan 20, 2008 | Sharp 13VT-R100 13 in. TV/VCR Combo
TV/DVD Combo
Is there a tape in the VCR by chance?.
Usually what happens on these combo units is the VCR develops a mechanical problem which inhibits the whole thing from working or overloads the power supply causing it to shutdown.
The ones with the VCR underneath are difficult to work on as the cables to the VCR are so short you have to disconnect it in order to get it out where you can see what is going on, then work on a solution, put it all back together, test it, rinse - lather - repeat. Takes forever sometimes. Find a good VCR tech and talk to him nice and maybe they will help you.
Jan 02, 2008 | Spectra KT2313 Combo
Lost remote control
You should easily be able to find a universal remote that works with your tv, search on the internet or go to an electronics store and tell them the specific brand and version [If its older than 1990 you will have a hard time finding one]
Dec 26, 2007 | Philips CCC132AT 13 in. TV/VCR Combo
Something wrong
A jammed or defective VCR can cause this symptom if the TV is turning itself off within about 15 seconds of turn on. Otherwise, it could be anything from a bad capacitor in the power supply to a shorted component in the High Voltage/deflection circuits. In other words, time to replace it.
Dec 18, 2006 | Sharp 13VT-R100 13 in. TV/VCR Combo
Tv shuts off after5 seconds
I,m sorry if not help you, but some those combo system when the Vcr have problem or stuck it shuts down, then you have to fix the Vcr frist. zcheck if the Vcr is ok. Aleixo
Aug 29, 2006 | eVision EC720E 20 in. TV/VCR/DVD Combo
Philips CCC132AT 13 in. TV/VCR Combo Logo
124 people viewed this question
Top Philips Combination Televisions Experts
matt martin
matt martin
Are you a Philips Combination Television Expert? Answer questions, earn points and help others
