How can i speed contral
Speed 33 45 all most very slow how can i speed ajust
  • 1,511 Answers
Drive belt needs replacing.
Posted on Apr 16, 2015
Us navy seth thomas clock runs slow?
If Hand Wind---Ajust screw device on swing arm clockwise
Mar 19, 2015 | Seth Thomas Audio Players & Recorders
Need to speed up my seth thomas wall mount hand wound clock
Can't Tell From Picture, But If It Has A Pendulem Ajust screw clockwise for faster (screw is last on arm)
Mar 15, 2015 | Seth Thomas Audio Players & Recorders
My sony walkman WM EX-190 is playing at low speed than normal. I changed the belt. bot still it is not playing at normal speed.
its maybe a failed speed ajustment or its slipped there is normally a tine whole on the back under the belt clip, press play and insert a small screw driver and turn u should find it speed up or slows down, if not its failed, but please be careful they are delicate anyhow
Jul 31, 2013 | Sony Audio Players & Recorders
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
Speeds up and slows down
Dear Sir:
Please adjust the sensor speed for the main motor. Of course I am recommending Very Strong to RUN the software calibration for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnosee
Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Nordic Track NordicTrack A2550 PRO...
Game sppeed too fast
You need to download a program that will normalise the speed if the speed settings in the game are normal you can ajust them to slow and that should normalize it on your machine.
May 25, 2009 | EA - Electronic Arts Command and Conquer:...
I have a 25hp evanrude (1994)tiller steer,would like to ask if the knob at the end of the tiller is for the slow running mixture,if so how is it ajusted as my motor runs ok at speed but mucks up at low...
this knob is a low idle stop
loosen the knob set the throttle to slow but running ok then tighten the knob
now the throttle will not go lower than this set point and die out
hope this helps
Apr 22, 2009 | Boating
Ajust speed
Yes, Unfortunately it is a technical solution, the twist grip speed control is a potentiometer (variable resistor) other then limited the amount the twist grip is turned , the only other way to limit the speed is to add a fixed resistor to the "top" end of the "pot", lets say you want a 10% reduction and you have a 1000 ohm pot you would add a 100 resistor to the "top" of the pot, if it doesnt work correctly change the connection to the other endof the pot
Mar 21, 2009 | Razor E100 Electric Scooter
137 people viewed this question
 Grubhead
Grubhead
