Question about Vacuums
What should I check on the power cord or the switch? That was a suggested possible cause. It is used on a dozen times b ut not under warranty.
Where is there a diagram for this
  • Anonymous Apr 16, 2015
    ORECK UPRIGHT Stopped running,
2 Suggested Answers
  • 694 Answers
SOURCE: Our Winsdor Sensor XP12 does
Any time the cord has been damaged badly enough to require taping, the possibility or intermittent "opens" exist. This means the wires are in contact much of the time, but will losed contact periodically. Even if it worked fine seconds ago, jiggling just right may cause this. This also presents a shock hazard.
I strongly recommend replacing the cord as soon as possible. If you are unable to do this, then please take it to a shop to be done.
Posted on Sep 01, 2010
Power cord warms up
They do get warm and that is normal. You will see it melt before it catches fire. The amount of electricty that is being used is close to the amount the cord can take.
Feb 15, 2014 | Hoover Vacuums
U5445-900
This is a good start, try this link...
Product Manual Search
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
How to replace power cable on hoover jc3157t
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 04, 2014 | Hoover Vacuums
My turbo plus does not turn on when plugged in. This is the first time this has happened. Any suggestions?
Check the power switch, plug cord and vacuum wiring. A open circuit will cause that and you need a continuity tester to test it. Once you find the trouble part, replace it with the same size and rating. A dent or vent wire will cause not to flow the current and voltage so check it.
Thanks for asking.
Jul 13, 2011 | Miele S514 Solaris Turbo Plus Vacuum
Power head attachment works great when plugged into the hose part of the vacuum. The problem is when I attach it to the tube for normal use there is no power. I have checked all the connections and...
try having someone turn the machine on and off while you pull the cord in and out with the cord more angled towards the on/off switch. Sometimes these models have a break in the cord rewind and will not put the power through to the motor.
Keep in mind this is repairable, and if the unit is less than 5 years old it should still be under warranty.
Good luck .
Nov 19, 2010 | Miele Vacuums
Our Winsdor Sensor XP12 does not show any power or lights, I did check the handle connection, it was fine. The power cord has been repaired with duct tape 3-4 x where someone has sucked up the cord, this...
Aug 31, 2010 | Windsor SR12 Sensor Bagged Upright Vacuum
My vacuum worked fine yesterday and now doesn't start
To my knowledge, the on/off switch is the only area to turn your vacuum on or off. There might be a problem with your cord, or with the switch itself. I suggest checking for clogs and anything that may cause a problem.
I also suggest taking it to a local vacuum shop to have it looked and as you may need some new parts (cord/switch)
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
S3501W will not light up or make steam.
Hi!!
Check fuse (where power cord goes into vacuum), if OK, check power cord for continuity.
Let me know how it worked out, good luck!
Mar 30, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Electrolux Centralux
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113669&thid=657359
Posted by Brucebob on Jun 09, 2008
I have an Electrolux Centralux. When I plug the hose in at one of the wall outlets the motor will not start. If I go to the motor and slap the unit it will start.....then...it will not stop unless I unplug the power cord to the motor.
If I plug the power cord back in, the unit will not restart until I slap the motor unit again. The unit has only been used 20 - 30 times.
Any suggestions? Thanks, Bruce
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may have a bad inlet or household outlet; try all the inlets in the house too. But it sounds to me that your carbon brushes are dirty and need cleaning or replacing would be my 1st suggestion. Take a good wire brushes or pipe cleaner to clean the inside of the carbon brushes if they stick then replace them. So if the unit has only been used 20 to 30 times I would suggest some one to come and look @ it who did the install because it is still under a factory warranty and if you start messing with things you will void the factory warranty on the motor. And then if it is the motor for some reason then the factory or vendor will eat the cost of the repair. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Electrolux Centralux Vacuum
Electrical
PROBLEM: THE KIRBY WILL NOT TURN ON AT ALL
POSSIBLE CAUSES:
Please note......The Kirby has TWO safety switches that need to be engaged before it will operate. One is on the fan case in the front. It is activated by having an attachment attached to the front. (hose, power nozzle, etc.) The other switch is on the side of the Kirby where the cloth bag attaches and is engaged by the little tab that sticks out from the side of the hard plastic cloth bag "boot". The bag boot MUST be completely engaged to activate the safety switch and allow the Kirby to power on. If you are having trouble getting the bag to properly engage, (sometimes they are STUBBORN) simply lubricate the black gasket that the boot fits onto with gasket lubricator, VASELINE, or try a tiny drop of DISHWASHING DETERGENT or HAND CREAM. It doesn't take much, so use the smallest amount possible to get the desired effect. You should hear a slight "pop" when the bag completely engages.
If neither of these things are indicated, it is probably again, either the power cord, switch or the carbon brushes.
If your Kirby is sparking there are a few causes...
PROBABLE CAUSE (MOTOR): Worn out carbon brushes, bad armature or perhaps BOTH
PROBABLE CAUSE (CORD): The cord has a short in it. Replace the power cord
PROBABLE CAUSE (POWER NOZZLE): There is something metallic stuck in the fan or power nozzle
I think you have a problem with the carbon brushes and amature because of where you describe seeing the sparks. I would suggest taking it to an authorized dealer for repair if it is the motor that is going bad.
Apr 01, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
