Question about Pool & Spa
Need a replacement start/run capacitor for a C56A31B17 AO Smith 3/4 HP 1725 RPM 110 V boat lift motor.
Century/Regal (which now owns AO Smith) has been giving me the run-around, says it's an OEM part, I guess they'd rather sell another motor instead of allowing me to repair it by putting in a new capacitor.
  • 3,382 Answers
Try your local granger store, they normally stock them. You can get them on eBay as well
Posted on Apr 16, 2015
Internal wiring diagram for a AO Smith 3/4hp 110/230v Frame 56 S#C56A31B17
look on the side of the motor it is wired for 220 volt from factory
Sep 29, 2014 | Pool & Spa
Motor just hums when boat lift switch turned up or down
This is usually caused when the motor sits awhile w/o being used. Remove the rear cover with a flat blade screwdriver or 1/4" nut driver. using a flat screwdriver, spin the armature clockwise. this should fix it. If you cannot spin it, the motor should be replaced.
Feb 21, 2014 | A O Smith Motors AO Smith Pump Motors,...
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
I have a Whisperflo Eplus 1.5HP pool pump. It has a A.O. Smith motor. the 50MFD 370VAC capacior is bad and needs to be replaced. Is the Capacitior a run capacitor or a start capacitor? Does it make a...
You didn't indicate exactly what AO Smith motor model you have, but most likely it's Capacitor start/run if it doesn't have a switch. The important thing is to replace with the same MFD as the old so you have the same starting characteristics. Here is a great link on AO Smith motors: http://www.discountpoolzone.com/poolmotor/pump_motor_university.pdf
Aug 13, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Pool & Spa Logo
195 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
