Question about Kitchen Appliances - Others
How to turn on
There doesn't seem to be an on/off switch. when I insert the blender cup, it doesn't turn on. It won't turn, push down or anything. Maybe it's broke.
  • 460 Answers
You may have to position blender cup so that it aligns with another mark somewhere before it locks in and starts.
Posted on Apr 18, 2015
I went to plug in my bullet and it won't turn on.
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
Apr 09, 2015 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
Nutribullet just stopped working,removed cup then replaced still no action...what now?
One probable reason for failure: The bottoms of the jars have outward-facing prongs which engage slots--incorporating integrated small power switches in the base. If those prongs break off or wear down--or, otherwise they can't make good contact by pushing inward those small switches (all of them)--your blender can't start.
It's an interlock safety feature intended to make certain users use the company's jars when starting their blenders. If the jar seems satisfactory, you may need to push down on the jar. (This reliance upon problematic plastic tabs holding up over time, in order to provide the safety feature, proves the "Achilles Heel" of this small kitchen appliance.
I've noted that Shark/Euro Pro appears to invoke a similar safety solution on their jars for at least some of their Ninja Blenders. The importer company behind Nutribullet still does offer replacement jars, I believe.
The company behind Nutribullet also warns users not to leave the base running for more than one minute at a time. (The system is designed to provide short, intense bursts of grinding and cutting power--not lengthy blending times.)
Aug 13, 2014 | Magic Bullet NutriBullet Nutrition...
Ninja 1100 single serve cup will not come off. it is stuck
I was just having the same problem and looking for a solution...then I found it myself by accident. By pulling up on the cup and then trying to turn it came off pretty easily. I was trying to push down, which seemed to make it tighter.
Jun 21, 2013 | Back to Basics 600 Smoothie Plus Work Top...
Food processor won't turn off
Probably going to require a new 3 button switch panel, they are not hard to fit.
Feb 17, 2013 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
Blades won't turn when cup is on
check to see if shaft is turning when cup is off if it is somthung is binding it
Sep 24, 2012 | Oster 6804 16 Speed Blender
My wolfgang puck 1.6 hp professional blender will not spin the blades if there is anything in the blender container.
This is not really the solution it is just a better description of the problem that I am also having. This is a great blender however the part where the cup blades conect to the motor is made of plastic.
So what has happened here is that the motor is fine, the cup is fine only the plastic part that makes the motor turn the blades has worn down therefore rendering the blender useless. I would like to know where I could get this small part to change on my blender!!!
Jul 30, 2012 | Wolfgang Puck 1.6 Hp Professional Blender...
The power button is flashing red in my ninja nj600
Arrow on lid, Arrow on handle. Line them up. I just did it. I knew it was something simple but I didn't think it would be that simple.
May 29, 2012 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Waring blender shoots food out the top
Are you blending something hot? When you blend a hot item the steam that is released will increase the pressure in the headspace above the contents in the blender. The lid will eventually blow off to release the pressure.
To avoid this problem begin blending with no more that one cup of ingredients. Before turning the blender on, remove the center lid insert to allow venting of steam. Blend on low speed. As you blend you can add another 1 1/2 cups of additional liquid through the opening in the lid.
Trust this method will resolve your problem.
Oct 22, 2011 | Waring 6000CG 60th Anniversary Blender
My magic bullet won't press down. It stays stuck and I cannot get the cup to push down onto the turning mechanism that is totally intact. It seems the side 3 pieces will not move downward when the cup is...
Had the same problem - it wouldn't press down. The little white plastic things inside of the base that go up and down when the cup is pushed down, were stuck. I think that something leaked into them so they wouldn't slide easily. I wiped out the inside of the base with a damp cloth and then I put a drop or two of WD40 at the top of the white plastic pieces and rubbed it up and down the length of all 3 of the white plastic pieces (this being done with the base lying on its side so the WD40 doesn't drip down into the mechanism). Then, with base upright, I used a screwdriver to try to manually push the white plastic pieces down. It worked. Of course before doing any of this - be sure the thing is unplugged (duh!).
Mar 18, 2010 | As Seen On TV Magic Bullet Food Processor
Kitchen Appliances - Others Logo
172 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
