It doesn't on - Office Equipment & Supplies
  • 1,511 Answers
If the problem cannot be fixed by establishing updated drivers; then, the problem is in the scanner control system. A printer may work fine as a stand alone unit, but the scanner could be defective and not function.
Posted on Apr 16, 2015
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Tip
How to hire android app develop?
While hiring android app developer, you should remind these things. Hiring a developer who
  • Doesn't Have a Good Sense of Product Behavior
  • Doesn't Own at Least One Good-Looking App on Google Play
  • Doesn't give Poor Time Estimations
  • Doesn't Have Experience with Releasing an App and Publishing It on Google Play
Hire Android App Developers Android App Programmers
on Feb 13, 2018 | Android Apps
DVD recorder doesn't work
what is the problem, doesn't turn on or doesn't record .
Sep 27, 2012 | Televison & Video
Dodge caravan 1996 doesnt start
It is very hard to help you when you give no details. But if it doesn't do anything when you try to start it you probably need to charge battery or get new one. If it is trying to start and doesn't sound weak then you need to have someone look at it. It doesn't sound like you would want to do anything yourself but if its not the battery, it doesn't sound good. Good luck
May 06, 2012 | 1996 Dodge Caravan
"Your phone doesn't support this USB headset"
The device doesn't support the USB headset. Please remove it.
Oct 06, 2011 | HTC F3188 Smartphone
Flash_integration.min.js i get this message everytime i load empireand allies game on zynga
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.2; EasyBits GO v1.0)
Timestamp: Sun, 18 Dec 2011 09:17:33 UTC
Message: Object doesn't support this property or method
Line: 1
Char: 209
Code: 0
URI: http://assets.castle.zgncdn.com/19555/js/flash_integration.min.js
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Line: 1
Char: 209
Code: 0
Sep 30, 2011 | Microsoft Internet Explorer 8
Epson 4800 set ink crtg error
Check the following information for reset the printer cartridge.......
http://www.fixya.com/support/t2689003-set_ink_cartridge_invalid_ink_cartridge
hope this helps you.
Oct 30, 2008 | Office Equipment & Supplies
178 people viewed this question
k24674
jasbo
jasbo
